Deleting a Raspberry Pi item from the Dashboard
I have just started using Cayenne and now have 2 Raspberry Pi on the Dashboard. However one of the Raspberry Pi was added when I was working on another circuit and I am no longer using that Device. How can remove one or both of the Pis that I have on the dashboard.
Select the Pi and click on settings ( a cog/gear bottom right on iOs view) - “remove device” should appear.
Worked exactly as you described. Thank you so much for your incredible quick response
                 Jerry Hoffman
