#define CAYENNE_DEBUG
#define CAYENNE_PRINT serial
char ssid[] = "******";
char wifiPassword[] = "*****";
char username[] = "******";
char password[] = "*******";
char clientID[] = "********";
pinMode(5, OUTPUT);
digitalWrite(0, LOW);
pinMode(2, OUTPUT);
digitalWrite(2, LOW);
CAYENNE_IN(6)
if (currentValue == 1)
//do whatever you want when you turn on the button on cayenne dashboard
digitalWrite(2, HIGH);
else
//do whatever you want when you turn off the button on cayenne dashboard
CAYENNE_IN(7)
digitalWrite(5, HIGH);
else
digitalWrite(5, LOW);
Am completely confused right now. Do i have to write my own sketch? isn’t that why we use cayenne?? The sketch given to me for upload when configuring the esp from my dashboard does not provide a spot for inputting my wifi details. the IDE always finds one error or another with the sketch when compiling also. can someone paste a sample code i can edit?
you must be using a Ethernet connection option while selecting device.
//#define CAYENNE_DEBUG
char ssid[] = "ssid";
unsigned long lastMillis = 0;
lastMillis = millis();
//Cayenne.luxWrite(2, 700);
NO. above code is to connect to cayenne and sends the current uptime in mills to cayenne dashboard.
to get value from cayenne use this code and add custom button widget with channel 1
CAYENNE_IN(1)
else
I am purposed to be as versed in the espressif chip as i am with the raspberry pi, seeing that i am more comfortable reading a python script than c++. so with that said, i have made great progress in uploading sketches. It is just remaining for the button to turn off/on the led.
I have the ground wire of the led connected to the controller’s gnd pin, and the 3v wire connected to pin D1. But for some reason my code only sends the uptime to the dashboard and does not turn on the led. please take a look at my code and tell me why that is
#include <ESP8266WiFi.h>
char ssid[] = "";
char wifiPassword[] = "";
char username[] = "";
char password[] = "";
char clientID[] = "";
Serial.begin(115200);
CAYENNE_IN(1)
digitalWrite(1, HIGH);
else
digitalWrite(1, LOW);
PIN D1 is GPI05 !! turn this as your void setup…copy… you have to adress the right pins !! D1-GPIO5…D2-GPI04…search google to get a ESP8266 E12 Pinout picture.
pinMode(5, OUTPUT);
i think so is ready if you copy this in your sketch ! i can’t test at this moment
