ESP8266-12E, Arduino, DHT22, BMP180, Cayenne
Nodemcu V.2 mit DHT22, BMP180 Sensoren verbinden und auf Cayenne Dashboarden
Nodemcu, DHT22, BMP180
-------Sketch---------
#define CAYENNE_DEBUG
#include "DHT.h"
#include <Wire.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BMP085_U.h> // BMP180 SDA-D2  SCL-D1
#define DHTPIN 14 // DHT22 Datapin to D5-GPIO14
#define DHTTYPE DHT22
char ssid[] = "";
char wifiPassword[] = "";
char username[] = "";
char password[] = "";
char clientID[] = "";
unsigned long lastMillis = 0;
Adafruit_BMP085_Unified bmp = Adafruit_BMP085_Unified(10180);
DHT dht(DHTPIN, DHTTYPE);
  dht.begin();
  Wire.begin(5, 4); // SDA, SDL
  if (!bmp.begin());
  sensors_event_t event;
    float humidity = dht.readHumidity();
    float temp1 = dht.readTemperature();
    float pressure;
    bmp.getPressure(&pressure);
    float temp2;
    bmp.getTemperature(&temp2);
    Cayenne.virtualWrite(1, temp1, TYPE_TEMPERATURE, UNIT_CELSIUS);
    Cayenne.virtualWrite(2, temp2, TYPE_TEMPERATURE, UNIT_CELSIUS);
    Cayenne.virtualWrite(3, temp1-temp2, TYPE_TEMPERATURE, UNIT_CELSIUS);
    Cayenne.virtualWrite(4, pressure/100, TYPE_BAROMETRIC_PRESSURE, UNIT_PASCAL);
    Cayenne.virtualWrite(5, humidity, TYPE_RELATIVE_HUMIDITY, UNIT_PERCENT);
Very cool! Thank you for sharing.
~Benny
Thanks Benny, I try to build something smart
Great!
Nice project write-up! It covers some widely used sensors too!
It was my first project, i´am playing since 7 days with this fantastic toys.
Thank you very much!! It works very well!!!
