I am using ESP8266 based Wemos D1 board to connect to Cayenne.
It rarely shows my device online even though widget is accurately shows my data coming from device.
Value widget shows the data and also shows chart when I click Details&Chart button. However, when I add Line Chart widget to see data from THE SAME channel, it tells me No Data Available.
When I want to add Analog Input Sensor, it does not let me choose device, even my device is online(after many tries and resets)
And one of my Line chart widgets seems to be magically missing from my dashboard even though I see its name on the left side. Ridiculous
I am just using simple sketch file.// This example shows how to connect to Cayenne using an ESP8266 and send/receive sample data.
//#define CAYENNE_DEBUG
char ssid = “Nijat”;
char wifiPassword = “xxxxxxxxxxx”;
char username = “xxxxxxxxxxxxxxx”;
char password = “xxxxxxxxxxxxxxx”;
char clientID = “xxxxxxxxxxxxxxx”;
unsigned long lastMillis = 0;
lastMillis = millis();
Cayenne.virtualWrite(V0,analogRead(0)); // 0 or V0 not matter
//Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
And there is more and more problems on every click, but you are organizing World’s First ESP8266 IoT contest
Finally, nothing is wrong with my device because I used it to build very complex projects with Adafruit IO.
I try to upload an image right now but that does not work either. It stuck at 100%.
