Hackable Christmas Greeting Card
You can support my entry for Arduino Christmas Contest here!
Introduction
Hey! Do you have a Christmas Greeting card? Bored and tired of it? Then this is your post.
In this post we will hack a cool Christmas Greeting Card with the possibility of changing the music, the led color (if you have one RGB) and brightness! All of this with Cayenne IoT to make it controllable with a smart phone! And we can make it also, our alarm clock!
Sneak Peak Video:
What you need before starting the project
Of course you need the materials I said before. You need a Cayenne Account, make one here. Then you need Cayenne Library. Simply search for MKR1000 sample Sketch and connect your board to Cayenne Dashboard.
CODE
Project created by Neoxelox for Hackster.io Arduino Contest 31/12/2016
Cayenne MKR1000 Example
This sketch connects to the Cayenne server using an Arduino/Genuino MKR1000 and runs the main communication loop.
Steps:
1. Install the Arduino SAMD Boards from the Arduino Boards Manager if you have not done so already.
2. Install the WiFi101 library (https://github.com/arduino-libraries/WiFi101) from the Arduino Library Manager if you have not done so already.
3. Select the Arduino/Genuino MKR1000 board and the correct port in the Arduino IDE.
4. Set the token variable to match the Arduino token from the Dashboard.
5. Set the network name and password.
6. Compile and upload this sketch.
#include <CayenneMKR1000.h>
#define LED_VIRTUAL_PIN V0
#define SONG_VIRTUAL_PIN V1
#define SONG2_VIRTUAL_PIN V2
#define SONG3_VIRTUAL_PIN V3
#define SONG4_VIRTUAL_PIN V4
#define SONG5_VIRTUAL_PIN V5
#define SONG6_VIRTUAL_PIN V6
#define SONG7_VIRTUAL_PIN V7
#define SONG8_VIRTUAL_PIN V8
char token[] = "*********";
char ssid[] = "*********";
char password[] = "**********";
int speakerPin = 6;
int leds = 5;
int yesno = 0;
//Buzzer-----------------------------------
int tempo = 150;
 pinMode(speakerPin, OUTPUT);
 pinMode(leds, OUTPUT);
//BUZZER-----------------------------------------------------------------------------
void playTone(int tone, int duration) {
 for (long i = 0; i < duration * 1000L; i += tone * 2) {
   digitalWrite(speakerPin, HIGH);
   delayMicroseconds(tone);
   digitalWrite(speakerPin, LOW);
void playNote(char note, int duration) {
 char names[] = { 'c', 'd', 'e', 'f', 's', 'g', 'a', 'v', 'b', 'C', 'D', 'E' };
 int tones[] = { 1915, 1700, 1519, 1432, 1352, 1275, 1136, 1073, 1014, 956, 852, 758 };
 // play the tone corresponding to the note name
 for (int i = 0; i < 8; i++) {
   if (names[i] == note) {
     playTone(tones[i], duration);
//BUZZER------------------------------------------------------------------------------
//CAYENNE VIRTUAL DASHBOARD-----------------------------------------------------------
CAYENNE_IN(LED_VIRTUAL_PIN)
 int currentValue = getValue.asInt(); // 0 to 1023
 analogWrite(leds, currentValue / 4); // must be from 0 to 255
//Ding Dong Merrily
CAYENNE_IN(SONG_VIRTUAL_PIN)
   yesno = getValue.asInt();
   if (yesno == 1){
   int length = 73;
   char notes[] = "ggagsed deggsgg ggagsed deggsgg DCbCDbCbabCabagabgagsgasgsesgeseddeggsgg "; // a space represents a rest
   int beats[] = { 2,2,1,1,1,1,4,2,2,2,2,2,2,4,2,2,2,2,1,1,1,1,4,2,2,2,2,2,2,4,2,2,3,1,1,1,1,1,3,1,1,1,1,1,3,1,1,1,1,1,3,1,1,1,1,1,3,1,1,1,1,1,3,1,2,2,2,2,2,2,4,2,2 };
   for (int i = 0; i < length; i++) {
        if (notes[i] == ' ') {
        delay(beats[i] * tempo); // rest
       } else {
       playNote(notes[i], beats[i] * tempo);
      // pause between notes
      delay(tempo / 2);
      if (yesno == 0){
          break;
//God Rest Ye Merry Gentlemen
CAYENNE_IN(SONG2_VIRTUAL_PIN)
   if (yesno == 1){
  int length = 69;
  char notes[] = "ddaagfedcdefga ddaagfedcdefga avgavCDagfdefgfgavaagfedfedgfgavCDagfed";
  int beats[] = { 2,2,2,2,2,2,2,2,2,2,2,2,2,4,2,2,2,2,2,2,2,2,2,2,2,2,2,2,4,2,2,2,2,2,2,2,2,2,2,2,2,2,2,4,2,2,4,2,2,2,2,2,2,4,1,1,2,4,2,2,2,2,2,2,2,2,2,2,8 };
       } else {
      delay(tempo / 2);
      if (yesno == 0){
          break;
//O Little Town of Bethlehem
CAYENNE_IN(SONG3_VIRTUAL_PIN)
   if (yesno == 1){
 int length = 71;
 char notes[] = "cfffgagavCavafggfcfffgagavCavafggffaCDCvagfgavCcfagfccfffgagavCavafggf ";
 int beats[] = { 2,2,2,2,2,1,1,1,1,2,2,2,1,1,2,2,6,2,2,2,2,2,1,1,1,1,2,2,2,1,1,2,2,6,1,1,3,1,1,1,1,1,1,1,1,1,2,2,2,2,2,2,4,4,2,2,2,2,1,1,1,1,2,2,2,1,1,2,2,6,2 };
       } else {
      delay(tempo / 2);
      if (yesno == 0){
          break;
//While Shephards Watched
CAYENNE_IN(SONG4_VIRTUAL_PIN)
   if (yesno == 1){
  int length = 29;
  char notes[] = "faagfvvagaCCbCaDCvagfeagffef ";
  int beats[] = { 2,3,1,2,2,2,2,2,2,2,2,2,2,6,2,3,1,2,2,2,2,2,2,2,2,2,2,6,2 };
       } else {
      delay(tempo / 2);
      if (yesno == 0){
          break;
//In The Bleak Midwinter
CAYENNE_IN(SONG5_VIRTUAL_PIN)
   if (yesno == 1){
  int length = 51;
  char notes[] = "aavCagfgagdgavCaggfgagff vavCDDaaCagfecavCagfgagff ";
  int beats[] = { 2,3,1,2,2,4,4,3,1,2,2,8,3,1,2,2,3,1,4,2,2,3,1,6,2,3,1,2,2,2,2,2,2,2,2,2,2,6,2,2,2,2,2,4,4,2,2,3,1,8,8};
       } else {
      delay(tempo / 2);
      if (yesno == 0){
          break;
//Hark the Herald
CAYENNE_IN(SONG6_VIRTUAL_PIN)
   if (yesno == 1){
  int length = 77;
  char notes[] = "cffefaagCCCvagacffefaagCffeedcCCCfvaagCCCfvaagDDDCvavgavCffgaDDDCvavgavCffgf ";
  int beats[] = {2,2,3,1,2,2,2,2,2,2,3,1,2,2,4,2,2,3,1,2,2,2,2,2,2,3,1,2,2,4,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,2,4,2,1,1,3,1,2,2,4,3,1,2,2,2,2,4,2,1,1,3,1,2,2,4,8};
       } else {
      delay(tempo / 2);
      if (yesno == 0){
          break;
//O come all Ye Faithful
CAYENNE_IN(SONG7_VIRTUAL_PIN)
   if (yesno == 1){
  int length = 64;
  char notes[] = "ggdgadbabCbaggsesgabsedd DCbCbabgasedggsgagdbbabCbabCbagsgCbagg ";
  int beats[] = { 2,4,2,2,4,4,2,2,2,2,4,2,2,4,2,2,2,2,2,2,4,3,1,6,2,4,2,2,4,4,2,2,2,2,3,1,2,2,2,2,2,2,4,2,2,2,2,2,2,4,2,2,2,2,2,2,4,2,2,4,3,1,6,8 };
       } else {
      delay(tempo / 2);
      if (yesno == 0){
          break;
//O Come O Come Emmanuel
CAYENNE_IN(SONG8_VIRTUAL_PIN)
   if (yesno == 1){
  int length = 63;
  char notes[] = "egbbbaCbagabgegasedeaaeesgsedgabbbaCbag DD bb baCdagabgegasede ";
  int beats[] = { 2,2,2,2,2,2,2,2,2,6,2,2,2,2,2,2,2,2,2,6,2,2,2,2,2,4,2,2,6,2,2,2,2,2,2,2,2,2,4,2,2,4,2,2,4,2,2,2,2,2,2,6,2,2,2,2,2,2,2,2,2,8,8 };
       } else {
      delay(tempo / 2);
      if (yesno == 0){
          break;
SCHEMATICS
Assembly
Retire the electronics parts the card has and just fill the greeting card with your electronics, if you have a MKR1000 without headers it will be easier.
Cayenne dashboard
Just put 8 buttons for the songs with Virtual connection and put the pins from V1 to V8. For the LED, in my case I only had a single color LED, go to Actuators>Light>Luminosity and select Digital connection with pin D5.
But you can also put 3 more buttons for changing the color of a RGB LED. If you want to make a Christmas Greeting Card alarm clock just go to Scheduler and make an event which will turn on one of the songs at a certain time.
Songs
The project has 8 Christmas songs, but you can put more. The play system is like this Arduino example but modified: http://www.arduino.cc/en/Tutorial/Melody
Well, as you could see in the video the volume was very low, so I recorded the songs with a microphone:
Very cool, I gave you an upvote. I couldn’t fine the detail on the contest – how much more time do people have to enter? We already have Christmas in October though so why not January?
I feel like the missing part is an email or SMS notification so you can be notified that your card recipient took the time to open/read it and didn’t tear straight into the present :smile:
That could be awesome with a IR Motion Sensor which could detect reader’s face, I didn’t thought that!
You have information about the contest here.
@bestes said the contest ended on the 30th :frowning:
It looks like that is actually January 30th, so there is still time.
