MQTT connect failed, error -1
I am using;
  • Arduino Mega 1280 with ESP8266
  • Web dashboard
I am trying to open/close a relay that is connected to my Arduino. But even if I could manage to connect, I can not perform any action.
On the web dashboard it simply shows me spinning dots, and then says the device is offline…
Here is my code btw;
#define CAYENNE_DEBUG       // Uncomment to show debug messages
#define VIRTUAL_CHANNEL 2
#define ACTUATOR_PIN 4
#include <ESP8266SerialLibrary.h>
char ssid[] = "ssid";
char wifiPassword[] = "password";
// Cayenne authentication info.
char username[] = "username";
char password[] = "password";
char clientID[] = "client_id";
// ESP8266 Serial object.
#define EspSerial Serial1
ESP8266 wifi(&EspSerial);
  delay(10);
  // Set ESP8266 baud rate
  EspSerial.begin(115200);
  //EspSerial.begin(115200);
  delay(50);
// Data from Cayenne.
CAYENNE_IN(VIRTUAL_CHANNEL)
  if (getValue.asInt() == 0)
    digitalWrite(ACTUATOR_PIN, HIGH);
  else
    digitalWrite(ACTUATOR_PIN, LOW);
// Send data to Cayenne
CAYENNE_OUT_DEFAULT()
  // Cayenne.virtualWrite(0, millis());
  //Cayenne.luxWrite(2, 700);
I am writing ssid and password of the WiFi, and username, clientID, password to the corresponding places of course.
New development:
After 5-6 “MQTT connect failed, error -1” messages it said “Connected”.
But my web dashboard says offline.
It said “Disconnected” again and started giving the same error message again…
There is currently a problem that is being worked on.
It was fixed yesterday but having the same issue today again… What is the latest status?
