PCA9685 on Raspberry Pi with two servos
I have Cayenne working with my Pi and have a PCA9685 connected and working using python test programming outside of Cayenne. I can control both servos no problem… In Cayenne I have it added to the Pi with the extension showing and adjusting through Base Rotate between 150 and 600 but I still do not get movement with the slider???
Any help? What more do you need to know?
Could it be related to the driver which I can’t find… wget http://responsive.mydevices.com/rpi/rpi_???.sh
I’ve found several different links but seem to be located with my command???
Turns out the slider range was too wide and required adjustment to much finer values with better resolution. Now resolved.
Thanks,
Thanks for the update, I’ll mark this as helped.
