Problem to connect Raspberry to Cayenne
I’m trying to reconnect my raspberry to Cayenne in the new version, I did the following:
I deleted Rasenberry from Cayenne since she was disconnected.
I ran the commands
wget https://cayenne.mydevices.com/dl/rpi_lcjnxth2k3.sh
sudo bash rpi_lcjnxth2k3.sh -v
I get the following error:
“The certificate of update mydevices.com is not trusted”
"update my devices.com hasn’t got a know issuer.
Did you create a new raspberry pi device when you added the raspberry pi for the second time?
~Benny
Hello, since I deleted Cayenne’s PI to install it on the new platform, I performed the process as if it were a new PI. Then I created a new PI.
Thank Benny
Francisco Amiama
Hello, I solved the problem of the Raspberry, I loaded the operating system again and I connected it to Cayenne, everything worked very well thank you very much
