Hi
The alarms and notiifications worked a treat. Thanks !
Suggestions:
1/. Fluctuating signals can cause multiple bursts of alarms / e-mails and txts so suggest either a nominal threshold of say 5% / 10% of range of alarm value or a programmable threshold or an alarm at x% and reset at y% of value… Getts messy I know…
2/. A toggle logic option… alarm is triggered ONCE until dashboard alarm acknowledge resets the sate
3/. Almost staring us in the face this one… But why not an option to activate an output (E.g. Generic OP lights LED, activates a sounder) on alarm. This just needs a third option in the ‘Then Notify’ box general area. This is getting pretty close to the general logic sand box / patch bay / relay board sort of idea in another post.
I would not mind just a python script window with the DI/DO, AI/ AO given semi symbolic meaning.
But would be interesting to see if someone can come up with a graphical ‘blocky’ dragy dropy wire diagram type system or library within the gui with blocks alongs the line of
IP - DI Hi / Lo pulse capture detected (lots of people after this)
IP - DI Digital pin
IP - AI Trigger >
IP - AI Trigger <
Timer wait x seconds then
IF > x seconds then
Delay timer (Passes input digital state by x amout of time)
If YY:MM:DD:hh:mm:ss = then
if xx:xx:DD=1-5:09:00:00 etc (Cron type thing ?)
OP set ana (PWM, Servo AO to = x)
Inc / Dec OP
OP Set DO (Hi:Lo)
OP Pulse single pin
OP pulse 1 or multi pin Pattern (shift out time base selectable)
Flip Flop R/R IP > Q OP
Logic (boolean family)
Radio Button
&c.
Now there is a challenge but I imagine you would not have to look too far.
~ Andrew
