Hello all! I have added a ds1820 temperature sensor to my dashboard,but it’s not showing when I try to add a trigger? I’ve rebooted with no change
Are you using the correct data type for the particular sensor ???
Thanks for the quick response! I’m not sure what you mean though? It’s on gpio 4 ( the 1 wire sensor terminal). It’s working, but not avail under add a trigger
You mean you have connected the dsb1820 to a raspberry pi. Can you share a screenshot 9f the trigger .
Can you private message me your email id
