I’m new to Cayenne and I have a simple problem. I have a dashboard with one EWATTCH Ambiance Sensor on TTN. By default the dashboard shows all available parameters as “Value”. This is Temperature, Humidity, Luminosity, Presence and technical parameters.
I can change all of them to show as value, graph or gauge. What I would like to do is to add “Temperature” once as “Value” and at the same time as “Graph”. Unfortunately I don’t fine a way to do that, is this possible?
what @margettepv mentioned is correct, but I guess you using the pre-configured payload which is creating those default widget.
Is this node programmable? is yes try using cayenne LPP Cayenne Features - Developer | myDevices.com
Thanks for your explanations! @shramik_salgaonkar is correct, I’m using a pre-configured node. I was hoping that there is a way to just duplicated the dashboard item. I would assumed this should be a cayenne “front-end” function, independent from the actual data received.
If there is no easy way, I will live with the current setup.
