I am pushing data from an Adeunis Dry Contact Sensor using The Things Network integration to Cayenne my Devices. Can you advise if the payload is being decoded correctly, as the Digital 1 and SNR channels appear to be mixed up?
Also, can you confirm what the channel numbers (found in the widget settings) should be for each part of the sensor payload (Battery, RSSI, SNR, Digital 1, Digital 2, Digital 3, Digital 4).
I am working with a client to create a LoRa network (14 Adeunis sensors and 4 DecentLab sensors) using Cayenne
as a means to visualise the sensor data.
I am using my clients myDevices/Cayenne account email which is
xxxxxxx
Below are the DEVEUI of three similar Adeunis sensors which are showing different things on Cayenne. I’ve included snapshots
from Cayenne as an aid.
DEVEUI: xxxxx (Digital 1 channel status shown but container is for SNR with Decibels as the unit)
The sensor SNR and Digital 1 widgets now populate correctly. Thanks for your quick help with that.
As a matter of interest, is it possible to format the display any further? For example to invert the value of a digital 0/1 type display?
When the sensor in question is configured as a 4-channel input, shorting an input signal to the “GND” terminal (to mimic a signal being turned off), results in a “1” being displayed on Cayenne whereas if the signal is driven high (to mimic a signal being turned on), Cayenne displays “0”. It would be really useful to be able to invert/flip the display.
