I have tryed both samples off the collections with add a new device here in Cayenne, with no result’s. Is there a way to see off the data is comming in to Cayenne?
The device’s or online in TTN (With changes or time) i got a message (Payload)
have set the intergration with Cayenne.
In Cayenne I have setup the devices, as I use all so other device’s (what is working)
But I don’t get any data availble in the dashboard, even I don’t see the whole payload soe where here.
what is the payload received at TTN?
the payload received at our end is AQIBAO8HHACmszIBcABkAND////B/6f/oP9HAAAAhP8AAAAAm8s= ===>base64 or 01 02 01 00 ef 07 1c 00 a6 b3 32 01 70 00 64 00 d0 ff ff ff c1 ff a7 ff a0 ff 47 00 00 00 84 ff 00 00 00 00 9b cb. ===> hex
In docs the first byte is the header and should be a fixed value FA
