Lorian
Hello together,
I am playing with Cayenne the first time and already got an error.
No data is shown at the dashboard or at the live-data-tab, just this error:
Error (1.656 sec)
Allowed memory size of 268435456 bytes exhausted (tried to allocate 262406236 bytes)
The TTGO T-Call (ESP32 with SIM800/MQTT) sends the data without any problems.
01:43:48.640 → Initializing modem…
01:43:58.002 → Modem: SIM800 R14.18
01:43:58.071 → [9884] Initializing modem
01:43:58.071 → [9952] Waiting for network
01:44:18.199 → [30069] Connecting to GPRS
01:44:25.166 → [37025] Connected to GPRS
01:44:25.166 → [37033] IP: 10.252.95.115
01:44:25.200 → [37033] Connecting to mqtt.mydevices.com:1883
01:44:26.782 → [38658] Connected
01:44:27.493 → [39375] Publish: topic 4, channel 65534, value ESP32, subkey , key
01:44:27.561 → [39397] Publish: topic 6, channel 65534, value XtensaLX6, subkey , key
01:44:27.664 → [39420] Publish: topic 7, channel 65534, value 240000000, subkey , key
01:44:27.730 → [39488] Publish: topic 5, channel 65534, value 1.3.0, subkey , key
01:44:27.799 → [39558] Publish: topic 8, channel 65534, value GSM, subkey , key
01:44:27.868 → OK!
01:44:30.361 → [42222] Publish: topic 1, channel 0, value 42222, subkey , key
01:44:30.429 → Sent all values - sleeping
These is just the demo-data-channel with the uptime-data.
I already tried to reregister the device, but with no luck. Another sensor/ESP32/WiFi/MQTT is working fine.
This does not seem to be the first time, this error occur and I already messaged @shramik_salgaonkar about this:
Does somebody know, how to solve it? Or at least, why it appears?
Thanks a lot,
lorian
Lorian
3
Of course, but it is a horrible bad quality:
#define CAYENNE_DEBUG
// TTGO T-Call pin definitions
#define MODEM_RST 5
#define MODEM_PWKEY 4
#define MODEM_POWER_ON 23
#define MODEM_TX 27
#define MODEM_RX 26
#define I2C_SDA 21
#define I2C_SCL 22
// Configure TinyGSM library
#define TINY_GSM_MODEM_SIM800 // Modem is SIM800
// This sketch uses a software serial connection.
#include <SoftwareSerial.h>
//SoftwareSerial gsmSerial(26, 27); // RX, TX
// If you are using a device that supports a hardware serial (Mega, Leonardo, etc.) and prefer to use
// that you can comment out the above lines and uncomment the one below.
#define gsmSerial Serial1
#include <CayenneMQTTGSM.h>
#include <Wire.h>
#include <TinyGsmClient.h>
#include "utilities.h"
// GSM connection info.
char apn[] = "pinternet.interkom.de"; // Access point name. Leave empty if it is not needed.
char gprsLogin[] = ""; // GPRS username. Leave empty if it is not needed.
char gprsPassword[] = ""; // GPRS password. Leave empty if it is not needed.
char pin[] = ""; // SIM pin number. Leave empty if it is not needed.
char username[] = "xxxxb4d4";
char password[] = "xxxx058d";
char clientID[] = "xxxxd412";
TinyGsm modem(Serial1);
TinyGsmClient client(modem);
int SleepTime = 60000000;
//Values sent/error booleans
bool CayenneSent = false;
// Keep power when running from battery
Wire.begin(I2C_SDA, I2C_SCL);
bool isOk = setPowerBoostKeepOn(1);
Serial.println(String("IP5306 KeepOn ") + (isOk ? "OK" : "FAIL"));
// Set-up modem reset, enable, power pins
pinMode(MODEM_PWKEY, OUTPUT);
pinMode(MODEM_RST, OUTPUT);
pinMode(MODEM_POWER_ON, OUTPUT);
digitalWrite(MODEM_PWKEY, LOW);
digitalWrite(MODEM_RST, HIGH);
digitalWrite(MODEM_POWER_ON, HIGH);
// Set GSM module baud rate and UART pins
Serial1.begin(115200, SERIAL_8N1, MODEM_RX, MODEM_TX);
delay(500);
// Restart takes quite some time
// To skip it, call init() instead of restart()
Serial.println("Initializing modem...");
modem.restart();
// Or, use modem.init() if you don't need the complete restart
String modemInfo = modem.getModemInfo();
Serial.print("Modem: ");
Serial.println(modemInfo);
//Serial.println("Setup Cayenne...");
Cayenne.begin(username, password, clientID, gsmSerial, apn, gprsLogin, gprsPassword, pin);
Serial.println("OK!");
delay(500);
Serial.println("Setup");
//Run Cayenne Functions
if (CayenneSent){
Serial.println("Sent all values - sleeping");
delay(100);
ESP.deepSleep(SleepTime);
delay(100);
CAYENNE_OUT_DEFAULT()
//Set CayenneSent to true so we know when to sleep
CayenneSent = true;
It is based on this: GitHub - Xinyuan-LilyGO/LilyGo-T-Call-SIM800
Thanks,
lorian
can you delete the widget from the dashboard and change:
to
Cayenne.virtualWrite(1, 22, "temp", "c");
after you upload the code, it will auto create a new green widget. Add it by clicking on “+” on the widget.
Also, i would suggest you remove the sleep for time being for testing.
