Servo cannot connect
sorry my english is bad
This example shows how to connect to Cayenne using an ESP8266 and send/receive sample data.
Steps:
1. If you have not already installed the ESP8266 Board Package install it using the instructions here: https://github.com/esp8266/Arduino#installing-with-boards-manager.
2. Select your ESP8266 board from the Tools menu.
//#define CAYENNE_DEBUG
#include <Servo.h>
char ssid[] = "kopiyen";
char wifiPassword[] = "bebas123";
char username[] = "0f3d2bb0-fe1b-11e9-84bb-8f71124cfdfb";
char password[] = "4f7d89bc3da5581de2a04b1f9750da8430591389";
char clientID[] = "0aefc090-0153-11eb-a67f-15e30d90bbf4";
#define VIRTUAL_CHANNEL 5
#define ACTUATOR_PIN D2
#define VIRTUAL_CHANNEL1 6
#define ACTUATOR_PIN1 D7
Servo s1;
Servo s2;
 s1.attach(ACTUATOR_PIN);
 s2.attach(ACTUATOR_PIN1);
CAYENNE_IN(VIRTUAL_CHANNEL)
  // Determine angle to set the servo.
  int position = getValue.asDouble() * 180;
  // Move the servo to the specified position.
  s1.write(position);
CAYENNE_IN(VIRTUAL_CHANNEL1)
  s2.write(position);
CAYENNE_OUT_DEFAULT()
  //Cayenne.luxWrite(2, 700);
    CAYENNE_IN_DEFAULT()
i used this and in data is sending the data but if i sliding on dashboard my servo is cannot rotating.
i use wemos d1 r1 and wemos d1 r2, sorry i cannot show my sketch cause i cannot find wemos d1 r1 or wemos d1 r2 on fritzing.
are you powering the servos from the wemos?
yes why? power is not enough?
yes, you need to power the servo externally, the wemos cant supply the needed power.
like pwm? or from ttl?
the power lines 5v and common ground lines.
if i use this? is enough?
What is the current rating fo this module. And do not connect it to the computer USB, use an power adapter.
rating? rating for what? quality or what?
current rating is the maximum current it can carry or supply.
okey, actually i am from indonesia and now is 9 pm so tomorrow i will try with prefer item
i can give you a workaround. Do you have an old mobile charger? You can cut the wire and use the red and black wire as 5v.
okay thanks for suggestion
