Don't get further than Setup 2 with Arduino Uno+Ethernert W5100
I am new in the mydevice community. Today I tried to set up an ArduinoUno with Ethernet W5100 shield.
I downloaded the libary and tried the example code from cayenne with the W5100 Ethernet. I compiled and uploaded it - ethernet and USB are plugged in. Port and the right board is choosed. Ethernet shield LEDs are blinking…
But my issue starts right at the beginning as when I click “next” in the Setup 2 on the homepage nothing happens. (I tried firefox an chrome)
Did I miss something?
I acutally wanted to use a Controllino Maxi for my projetct but same probleme here.
Here the example code:
char username = “MQTT_USERNAME”;
char password = “MQTT_PASSWORD”;
char clientID = “CLIENT_ID”;
CAYENNE_OUT_DEFAULT()
//Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
Hope someone can tell me whats wrong =) Thank you!
Problem Solved!
