i try this :
Web client
This sketch connects to a website (http://www.google.com)
using an Arduino Wiznet Ethernet shield.
Circuit:
- Ethernet shield attached to pins 10, 11, 12, 13
created 18 Dec 2009
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe, based on work by Adrian McEwen
#include <SPI.h>
#include <Ethernet2.h>
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
// if you donât want to use DNS (and reduce your sketch size)
// use the numeric IP instead of the name for the server:
//IPAddress server(74,125,232,128); // numeric IP for Google (no DNS)
char server = âwww.google.comâ; // name address for Google (using DNS)
// Set the static IP address to use if the DHCP fails to assign
IPAddress ip(192, 168, 0, 177);
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetClient client;
// Open serial communications and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
// start the Ethernet connection:
if (Ethernet.begin(mac) == 0) {
Serial.println(âFailed to configure Ethernet using DHCPâ);
// no point in carrying on, so do nothing forevermore:
// try to congifure using IP address instead of DHCP:
Ethernet.begin(mac, ip);
// give the Ethernet shield a second to initialize:
delay(1000);
Serial.println(âconnectingâŚâ);
// if you get a connection, report back via serial:
if (client.connect(server, 80)) {
Serial.println(âconnectedâ);
// Make a HTTP request:
client.println(âGET /search?q=arduino HTTP/1.1â);
client.println(âHost: www.google.comâ);
client.println(âConnection: closeâ);
client.println();
else {
// kf you didnât get a connection to the server:
Serial.println(âconnection failedâ);
// if there are incoming bytes available
// from the server, read them and print them:
if (client.available()) {
char c = client.read();
Serial.print(c);
// if the serverâs disconnected, stop the client:
if (!client.connected()) {
Serial.println();
Serial.println(âdisconnecting.â);
client.stop();
// do nothing forevermore:
while (true);
and the pcs âŚ
the arduino ip is :192.168.0.6 de:ad:be:ef:fe:ed
