Dear readers,
I use Cayenne for some projects involving a Raspberry Pi. Last week I got a Seeed Wio Terminal and I would like to use it with Cayenne too. Sadly I don’t get it working because I have almost no knowledge with the Arduino IDE (and I have to use the Arduino IDE for WiFi functions). I checked for libraries which support Cayenne and the Wio Terminal or at least the SAMD51 microcontroller, but didn’t find anything. If I use the Cayenne examples I get always errors like:
fatal error: WiFi101.h: No such file or directory
and:
Error compiling for board Seeeduino Wio Terminal.
So I tried replacing the code snippet which includes the WiFi101.h to rpcWiFi.h (which works for the Wio Terminal), but then I end up with this error:
WiFi101Shield:38:23: error: expected constructor, destructor, or type conversion before ‘;’ token
CAYENNE_OUT_DEFAULT()
WiFi101Shield:50:22: error: expected constructor, destructor, or type conversion before ‘;’ token
CAYENNE_IN_DEFAULT()
/var/folders/js/bx64jptd3zng91q6817lf26m0000gn/T/arduino_modified_sketch_747223/WiFi101Shield.ino: In function ‘void setup()’:
WiFi101Shield:29:2: error: ‘Cayenne’ was not declared in this scope
/var/folders/js/bx64jptd3zng91q6817lf26m0000gn/T/arduino_modified_sketch_747223/WiFi101Shield.ino: In function ‘void loop()’:
WiFi101Shield:33:2: error: ‘Cayenne’ was not declared in this scope
/var/folders/js/bx64jptd3zng91q6817lf26m0000gn/T/arduino_modified_sketch_747223/WiFi101Shield.ino: At global scope:
WiFi101Shield:38:21: error: ISO C++ forbids declaration of ‘CAYENNE_OUT_DEFAULT’ with no type [-fpermissive]
/var/folders/js/bx64jptd3zng91q6817lf26m0000gn/T/arduino_modified_sketch_747223/WiFi101Shield.ino: In function ‘int CAYENNE_OUT_DEFAULT()’:
WiFi101Shield:41:2: error: ‘Cayenne’ was not declared in this scope
WiFi101Shield:50:20: error: ISO C++ forbids declaration of ‘CAYENNE_IN_DEFAULT’ with no type [-fpermissive]
/var/folders/js/bx64jptd3zng91q6817lf26m0000gn/T/arduino_modified_sketch_747223/WiFi101Shield.ino: In function ‘int CAYENNE_IN_DEFAULT()’:
WiFi101Shield:52:38: error: ‘request’ was not declared in this scope
/var/folders/js/bx64jptd3zng91q6817lf26m0000gn/T/arduino_modified_sketch_747223/WiFi101Shield.ino:52:38: note: suggested alternative: ‘renameat’
renameat
WiFi101Shield:52:55: error: ‘getValue’ was not declared in this scope
/var/folders/js/bx64jptd3zng91q6817lf26m0000gn/T/arduino_modified_sketch_747223/WiFi101Shield.ino:52:55: note: suggested alternative: ‘getpass’
getpass
WiFi101Shield:52:2: error: ‘CAYENNE_LOG’ was not declared in this scope
/var/folders/js/bx64jptd3zng91q6817lf26m0000gn/T/arduino_modified_sketch_747223/WiFi101Shield.ino:52:2: note: suggested alternative: ‘CAYENNE_PRINT’
CAYENNE_PRINT
Does anybody have an idea how to make this example work for the Wio Terminal or how to connect the Wio Terminal to Cayenne? I used the WiFi101shield example for this one, but the other connection examples give the same kind of errors.
