I used this code and this configuration in the page of cayenne for conect Arduino UNO + ESP8266 (ESP01), then I modified this code to write the code used for the projec:
Steps:
- Install the ESP8266SerialLibrary.zip library via the Arduino IDE (Sketch->Include Library->Add .ZIP Library) from the Cayenne extras/libraries
- Connect the ESP8266 as a shield to your Arduino. This example uses the Serial1 hardware serial pins available on the Mega. You can also try
- Set the network name and password.
- Compile and upload the sketch.
- A temporary widget will be automatically generated in the Cayenne Dashboard. To make the widget permanent click the plus sign on the widget.
char ssid = “ssid”;
char wifiPassword = “wifiPassword”;
char username = “69f8c2b0-46ca-11ea-a38a-d57172a4b4d4”;
char password = “fa8e580b3e8adf4d400c731aa5e722202e3be649”;
char clientID = “f163e4f0-51ce-11ea-a38a-d57172a4b4d4”;
#define EspSerial Serial1
ESP8266 wifi(&EspSerial);
delay(10);
// Set ESP8266 baud rate
EspSerial.begin(115200);
delay(10);
CAYENNE_OUT_DEFAULT()
//Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
