Hi Guys
I am attempting to complete the first tutorial and connect to Cayenne. I have an Arduino with w5100 ethernet sheild. Got Arduino IDE copied and pasted the sketch, got the CayenneMQTT library. When I try to compile I get this.
Arduino: 1.8.12 (Windows 7), Board: “Arduino Uno”
In file included from C:\Users\Documents\Arduino\sketch_mar13a\sketch_mar13a.ino:6:0:
C:\Users\Documents\Arduino\libraries\CayenneMQTT\src/CayenneMQTTESP8266.h:25:10: fatal error: ESP8266WiFi.h: No such file or directory
#include <ESP8266WiFi.h>
compilation terminated.
exit status 1
Error compiling for board Arduino Uno.
This is the Sketch with the Library included.
#include <CayenneArduinoDefines.h>
#include <CayenneArduinoMQTTClient.h>
#include <CayenneHandlers.h>
#include <CayenneMessage.h>
#include <CayenneMQTTESP32.h>
#include <CayenneMQTTEthernetClient.h>
#include <CayenneMQTTEthernetW5200.h>
#include <CayenneMQTTEthernetW5500.h>
#include <CayenneMQTTGSM.h>
#include <CayenneMQTTGSMClient.h>
#include <CayenneMQTTMKR1000.h>
#include <CayenneMQTTSerialClient.h>
#include <CayenneMQTTWiFi.h>
#include <CayenneMQTTWiFi101.h>
#include <CayenneMQTTWiFiClient.h>
#include <CayenneMQTTYun.h>
#include <CayenneMQTTYunClient.h>
#include <CayenneTMP102.h>
#include <CayenneVCNL4000.h>
#include <DetectDevice.h>
Steps:
- Compile and upload the sketch.
- A temporary widget will be automatically generated in the Cayenne Dashboard. To make the widget permanent click the plus sign on the widget.
char username = “abe791e0-017d-11e8-8ebb-078f03a4ea8d”;
char password = “d7f5d993d9c2518265a62bd68ecfa5361419f642”;
char clientID = “9fca2180-6598-11ea-84bb-8f71124cfdfb”;
CAYENNE_OUT_DEFAULT()
//Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
Can someone Please Help?
