Hello.
I’m collecting temperature data.
Is it possible for me to average this data within an hour?
Thank you!
Hello.
Thank you!
can you provide more detail on this?
Thank you .
I am collecting and sending data every 5 minutes. So I wanted to average those data within one hour.
Could I be clearer?
you want to download the averaged one hour data from cayenne?
I wanted to know if you can average within the Cayenne application.
Pick up the data every 5 minutes and after an hour average them.
not possible on cayenne but you can do that locally on your device.
Yes, but I need the data every 5 minutes and only then average. Because if I do on the device I can only send it every 1 hour.
you can use two separate channel.
Channel 1 sends data every 5 minutes.
Channel 2 sends data after averaging every 1 hour
And how can I do that?
can you share the code you are using?
