I am using a RP2040 COnnect Arduino with Cayenne and I am able connect and send data from my controller to the dashboard but when I try to put a button widget and send data to the controller and the message is received but the button keeps loading forever.
My code is below ![]()
#include <SPI.h>
#include <WiFiNINA.h>
#include <PubSubClient.h>
#include <Arduino_LSM6DSOX.h>
int hydrogen;
int temperature_deg;
float x, y, z;
//#include "arduino_secrets.h"
///////please enter your sensitive data in the Secret tab/arduino_secrets.h
char ssid[] = "TELUSWiFi0280"; // your network SSID (name)
char pass[] = "8m4c8DbzKz"; // your network password (use for WPA, or use as key for WEP)
int status = WL_IDLE_STATUS; // the WiFi radio's status
#define MQTT_SERVER "mqtt.mydevices.com"
#define MQTT_SERVERPORT 1883
#define MQTT_USERNAME "973c1410-f0b0-11ec-9f5b-45181495093e"
#define MQTT_PASSWORD "ba071053e33cabd2a7fe0149e2b52c34c01323b1"
#define CLIENT_ID "402c18d0-f314-11ec-a681-73c9540e1265"
#define MQTT_TOPIC_HYDROGEN "v1/" MQTT_USERNAME "/things/" CLIENT_ID "/data/1"
#define MQTT_TOPIC_X "v1/" MQTT_USERNAME "/things/" CLIENT_ID "/data/2"
#define MQTT_TOPIC_Y "v1/" MQTT_USERNAME "/things/" CLIENT_ID "/data/3"
#define MQTT_TOPIC_Z "v1/" MQTT_USERNAME "/things/" CLIENT_ID "/data/4"
#define MQTT_TOPIC_BOARD_TEMP "v1/" MQTT_USERNAME "/things/" CLIENT_ID "/data/5"
#define MQTT_TOPIC_LED "v1/" MQTT_USERNAME "/things/" CLIENT_ID "/cmd/6"
WiFiClient espClient;
PubSubClient client(MQTT_SERVER, MQTT_SERVERPORT, espClient);
//Defineining a datatype to store the mqtt message, up to 50 bytes
char msg[50];
long timeStampNow;
long timeStampLastMsg = 0;
// Initialize serial monitor for debugging purposes.
Serial.println("DEBUG: Entering setup ");
// Attempt to connect to WiFi.
WiFi.begin(ssid, pass);
Serial.println();
Serial.println();
Serial.print("Connecting to ");
Serial.println(ssid);
// check for the WiFi module:
if (WiFi.status() == WL_NO_MODULE) {
Serial.println("Communication with WiFi module failed!");
// don't continue
while (true);
String fv = WiFi.firmwareVersion();
if (fv < WIFI_FIRMWARE_LATEST_VERSION) {
Serial.println("Please upgrade the firmware");
// attempt to connect to WiFi network:
while (status != WL_CONNECTED) {
Serial.print("Attempting to connect to WPA SSID: ");
// Connect to WPA/WPA2 network:
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
// delay(2000);
// you're connected now, so print out the data:
Serial.print("You're connected to the network");
//Accelerometer setup
if (!IMU.begin()) {
Serial.println("Failed to initialize IMU!");
while (1);
Serial.print("Accelerometer sample rate = ");
Serial.print(IMU.accelerationSampleRate());
Serial.println(" Hz");
Serial.println();
Serial.println("Acceleration in g's");
Serial.println("X\tY\tZ");
//Onboard temperature sensor setup
if (IMU.temperatureAvailable()){
int temperature_deg = 0;
// Initialize MQTT PubSub Library
client.setServer(MQTT_SERVER, MQTT_SERVERPORT);
// Function called in case of an incomming mqtt message from Cayenne Dashboard
// (In this case is the dashboard button to turn on/off the heater)
client.setCallback(mqttCallback);
Serial.println("DEBUG: Setup Done! ");
// -------------------- LOOOP -------------------
// Check if the esp8266 is connected to the mqtt server.
if (!client.connected()) {
reconnect();
// If connected, perform PubSubClient housekeeping function.
client.loop();
// Publish temperature readings every 2 seconds (2000ms)
timeStampNow = millis();
if (timeStampNow - timeStampLastMsg > 5000) { // Publish interval in milliseconds
// Reset the counter
timeStampLastMsg = timeStampNow;
// Jump to the actual function to read and publish temperatures.
hydrogendata();
accelerometer();
board_temp();
delay(1000);
//Serial.println("DEBUG: Reached MAIN LOOP END --> Looping ");
// ------------------------------ OTHER FUNCTIONS
// Function that attempts to reconnect to the mqtt server.
void reconnect() {
// If esp8266 is disconnected from the mqtt server, try to reconnect.
// (*** I still need to think what wil happen to the boiler if connection is lost ***)
while (!client.connected()) {
Serial.print("DEBUG: Attempting MQTT connection...");
if (client.connect(CLIENT_ID, MQTT_USERNAME, MQTT_PASSWORD)) {
Serial.println("connected");
// Once connected, resubscribe to the Dashboard on/off button topic.
// client.subscribe(MQTT_TOPIC_BTN_ONOFF);
client.subscribe(MQTT_TOPIC_LED);
} else {
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
//Serial.println("DEBUG: Quiting reconnect loop ");
// Function that handles temperature adquisition from sensors, and publishing to Cayenne Dashboard.
void hydrogendata(){
hydrogen = analogRead(A0);
// Construct the mqtt message following Cayenne's rules, according to the Docs..
// Send Sensor data -> Topic: v1/username/things/clientID/data/channel
//using a float rounded to 2 decimal places.
String hydrogen_message = String(hydrogen);
Serial.println(hydrogen_message);
mqtt_message(hydrogen_message);
// Finally! Publish the temperature to Cayenne Dashboard, Channel 1.
client.publish(MQTT_TOPIC_HYDROGEN,msg);
void mqtt_message(String message){
// Convert the string into a Char Array
message.toCharArray(msg, 50);
Serial.print("Publish message: ");
Serial.println(msg);
void accelerometer(){
if (IMU.accelerationAvailable()) {
IMU.readAcceleration(x, y, z);
Serial.print(x);
Serial.print('\t');
Serial.print(y);
Serial.print('\t');
Serial.println(z);
String acc_x_message = String(x);
String acc_y_message = String(y);
String acc_z_message = String(z);
//Publishing accelerometer values to Cayenne Dashboard, Channel 2-4
mqtt_message(acc_x_message);
client.publish(MQTT_TOPIC_X,msg);
mqtt_message(acc_y_message);
client.publish(MQTT_TOPIC_Y,msg);
mqtt_message(acc_z_message);
client.publish(MQTT_TOPIC_Z,msg);
void board_temp(){
IMU.readTemperature(temperature_deg);
String onboard_temp = String(temperature_deg);
mqtt_message(onboard_temp);
client.publish(MQTT_TOPIC_BOARD_TEMP,msg);
// Function to intercept MQTT messages
void mqttCallback(char* topic, byte* payload, unsigned int length) {
Serial.print("Message arrived in topic: ");
Serial.println(topic);
Serial.print("Message:");
for (int i = 0; i < length; i++) {
Serial.print((char)payload[i]);
Serial.println();
Serial.println("-----------------------");
