Please can someone help for this question(Can I use Cayenne for an IR(infrared) project).
need more info on this topic.
I want to make a project about recieving specific IR codes(ex. air conditioner), saving them and identity them. By doing that I should be able to control an IR device (in this case the air conditioner) through the website.
Are you able to identify and save them ? Once done you can easily control them using cayenne.
That actually was the point of the question(Am I able to identify and save the IR sensors ?). But as I can see it is possible regarding to this project that you sent. Thank you very much !
if you are looking to control it via raspberry then have a look at this Air conditioner on/off control (raspberry pi)
No , I want to control it via arduino, but thank you anyways. You helped me a lot.
