I’m using a Raspberry PI 3 with an 8-relay board connected to the GPIO as a simple sprinker control unit.
I’m using the Web dashboard.
I’ve added 5 Valve Switch Actuators, which work regularly when manually activated.
I’m trying to set up the scheduler in order to program a daily routine.
However the web interface is not allowing me to set the proper action.
The only available actions are Reboot/Shutdown even if I choose the proper widget:
Am I doing anything wrong?
Also, I’d like to know some details about the scheduler: is the scheduler programming downloaded locally to my raspberry? What happens if the internet link goes down during event time activation?
