Cayenne and air pollution
Hi all, does anybody know if there is a way to use Cayenne to monitor air pollution. I was thinking a PMS5003?
first are you able to read the sensor data to arduino or any other mc?
Hi
Sharmik, thanks for your email.
I know you run it on a pi, so the answer is yes but as yet not built it. However, you have to run the software that drives it obviously so yes is the answer.
once you get the reading you can use GitHub - myDevicesIoT/Cayenne-MQTT-Python: Python Library for Cayenne MQTT API to send the sensor data to cayenne.
Brilliant, thank you
I’m out at the moment, but will have a good read when I get home. Happy New Year! And thanks again
