More info/output from Ricks Raspberry Pi:
pi@raspberrypi:~ $ arp -a
? (192.168.1.254) at a4:ba:76:41:8c:0a [ether] on wlan0
pi@raspberrypi:~ $ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/root 30G 4.4G 24G 16% /
devtmpfs 459M 0 459M 0% /dev
tmpfs 463M 104M 360M 23% /dev/shm
tmpfs 463M 6.4M 457M 2% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 463M 0 463M 0% /sys/fs/cgroup
/dev/mmcblk0p1 42M 21M 21M 50% /boot
tmpfs 93M 0 93M 0% /run/user/0
tmpfs 93M 0 93M 0% /run/user/1000
pi@raspberrypi:~ $ ip addr
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
valid_lft forever preferred_lft forever
inet6 ::1/128 scope host
2: eth0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
link/ether b8:27:eb:96:00:a9 brd ff:ff:ff:ff:ff:ff
inet6 fe80::a6b6:6b1c:b6a2:af0d/64 scope link tentative
3: wlan0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
link/ether b8:27:eb:c3:55:fc brd ff:ff:ff:ff:ff:ff
inet 192.168.1.72/24 brd 192.168.1.255 scope global wlan0
inet6 fda4:ba76:418c:a00:1c56:cc16:c97b:656e/64 scope global noprefixroute dynamic
valid_lft 6832sec preferred_lft 3232sec
inet6 fe80::a975:75a7:4967:a3f2/64 scope link
pi@raspberrypi:~ $ ping cloud.mydevices.com
PING cloud.mydevices.com (54.173.248.213) 56(84) bytes of data.
^C
— cloud.mydevices.com ping statistics —
15 packets transmitted, 0 received, 100% packet loss, time 14004ms
$ telnet cloud.mydevices.com 8181
Trying 54.173.248.213…
Connected to cloud.mydevices.com.
Escape character is ‘^]’.
telnet> quit
Connection closed.
pi@raspberrypi:~ $ which nslookup
pi@raspberrypi:~ $ which dig
pi@raspberrypi:~ $ which ping
/bin/ping
pi@raspberrypi:~ $ ping google.com
PING google.com (216.58.216.46) 56(84) bytes of data.
64 bytes from lax02s22-in-f46.1e100.net (216.58.216.46): icmp_seq=1 ttl=57 time=26.5 ms
64 bytes from lax02s22-in-f46.1e100.net (216.58.216.46): icmp_seq=2 ttl=57 time=30.2 ms
64 bytes from lax02s22-in-f46.1e100.net (216.58.216.46): icmp_seq=3 ttl=57 time=23.7 ms
^C
— google.com ping statistics —
3 packets transmitted, 3 received, 0% packet loss, time 2002ms
rtt min/avg/max/mdev = 23.760/26.850/30.222/2.648 ms
pi@raspberrypi:~ $ sudo netstat -natp | grep -i established
Active Internet connections (servers and established)
tcp 0 0 192.168.1.72:37084 199.96.57.6:443 ESTABLISHED 1612/libpepflashpla
tcp 0 0 192.168.1.72:50210 107.23.65.136:443 ESTABLISHED 1612/libpepflashpla
tcp 0 0 192.168.1.72:58470 34.199.178.126:8181 ESTABLISHED 1134/python3
tcp 0 0 192.168.1.72:40474 107.23.65.136:443 ESTABLISHED 1612/libpepflashpla
tcp 0 0 192.168.1.72:51670 216.58.193.206:443 ESTABLISHED 1612/libpepflashpla
tcp 0 0 192.168.1.72:50062 107.23.65.136:443 ESTABLISHED 1612/libpepflashpla
tcp 0 0 192.168.1.72:34468 64.71.168.200:80 ESTABLISHED 1612/libpepflashpla
tcp 0 0 192.168.1.72:41930 34.214.166.89:443 ESTABLISHED 1612/libpepflashpla
tcp 0 0 127.0.0.1:34981 127.0.0.1:51362 ESTABLISHED 1020/vncserverui
tcp 0 0 192.168.1.72:43552 216.58.216.46:443 ESTABLISHED 1612/libpepflashpla
tcp 0 0 192.168.1.72:52384 216.58.193.212:443 ESTABLISHED 1612/libpepflashpla
tcp 0 0 192.168.1.72:50206 107.23.65.136:443 ESTABLISHED 1612/libpepflashpla
tcp 0 0 192.168.1.72:33662 64.71.168.200:80 ESTABLISHED 1612/libpepflashpla
tcp 0 0 127.0.0.1:51362 127.0.0.1:34981 ESTABLISHED 617/vncserver-x11-c
tcp 0 0 192.168.1.72:57518 52.45.215.199:443 ESTABLISHED 1612/libpepflashpla
tcp 0 0 192.168.1.72:54740 54.148.242.35:443 ESTABLISHED 1612/libpepflashpla
pi@raspberrypi:~ $ which telnet
/usr/bin/telnet
telnet> quit
Connection closed.
pi@raspberrypi:~ $ sudo service myDevices status
● myDevices.service - myDevices service
Loaded: loaded (/etc/systemd/system/myDevices.service; enabled)
Active: active (running) since Wed 2017-11-29 19:02:01 UTC; 22min ago
Main PID: 1134 (python3)
CGroup: /system.slice/myDevices.service
‣ 1134 /usr/bin/python3 -m myDevices -P /var/run/myDevices.pid
Nov 29 19:02:01 raspberrypi systemd[1]: Started myDevices service.
Nov 29 19:02:01 raspberrypi systemd[1134]: pam_exec(login:session): conversation failed
Nov 29 19:02:01 raspberrypi systemd[1134]: pam_unix(login:session): session opened for user root by (uid=0)
pi@raspberrypi:~ $ sudo service webiopi status
● webiopi.service - LSB: WebIOPi initscript
Loaded: loaded (/etc/init.d/webiopi)
Active: active (running) since Wed 2017-11-29 19:01:50 UTC; 23min ago
Process: 541 ExecStart=/etc/init.d/webiopi start (code=exited, status=0/SUCCESS)
CGroup: /system.slice/webiopi.service
└─566 /usr/bin/python3 -m webiopi -l /var/log/webiopi -c /etc/webiopi/config
Nov 29 19:01:50 raspberrypi systemd[1]: Starting LSB: WebIOPi initscript…
Nov 29 19:01:50 raspberrypi systemd[1]: Started LSB: WebIOPi initscript.
pi@raspberrypi:~ $ ps axu | grep python
root 566 3.3 1.4 36040 13688 ? Sl 19:01 0:49 /usr/bin/python3 -m webiopi -l /var/log/webiopi -c /etc/webiopi/config
root 1134 14.8 2.2 138084 21732 ? Ssl 19:02 3:32 /usr/bin/python3 -m myDevices -P /var/run/myDevices.pid
pi 5602 0.0 0.2 4280 2020 pts/0 S+ 19:26 0:00 grep --color=auto python
pi@raspberrypi:~ $ cat /etc/myDevices/Network.ini
[CONFIG]
CayenneApi=https://api.mydevices.com
ServerAddress=cloud.mydevices.com
ServerPort=8181
pi@raspberrypi:~ $ sudo tail -n 50 /var/log/myDevices.log
2017-11-29 19:24:19 - myDevices - INFO - History CalculateAverages increment: 47
2017-11-29 19:24:19 - myDevices - INFO - Calculate sensor info averages: {‘SensorsInfo’: {‘a12b9a0f4ee53d2fb60542447dde52a49d1c5389’: 46, ‘d4d858ffde48264d728d1698381031fa1da034ee’: 46, ‘068702351c9d2ff6fe80b55483ee995d9d3d127b’: 46, ‘07fb628cedbff2baa2f0880a934fd5421c2244e6’: 46}}
2017-11-29 19:24:19 - myDevices - INFO - Save History Averages
2017-11-29 19:24:19 - myDevices - INFO - Memory usage : 45 size: 21724
2017-11-29 19:24:19 - myDevices - INFO - Resouce usage info: resource.struct_rusage(ru_utime=177.69, ru_stime=19.27, ru_maxrss=21724, ru_ixrss=0, ru_idrss=0, ru_isrss=0, ru_minflt=420145, ru_majflt=6, ru_nswap=0, ru_inblock=4680, ru_oublock=5416, ru_msgsnd=0, ru_msgrcv=0, ru_nsignals=0, ru_nvcsw=89565, ru_nivcsw=31933)
2017-11-29 19:24:19 - myDevices - INFO - PacketTypes.PT_SYSTEM_INFO
2017-11-29 19:24:19 - myDevices - INFO - PacketTypes.PT_UTILIZATION
2017-11-29 19:24:28 - myDevices - INFO - SendHistoryData previously SendFailed items:
2017-11-29 19:24:49 - myDevices - INFO - History CalculateAverages increment: 48
2017-11-29 19:24:49 - myDevices - INFO - Calculate sensor info averages: {‘SensorsInfo’: {‘a12b9a0f4ee53d2fb60542447dde52a49d1c5389’: 47, ‘d4d858ffde48264d728d1698381031fa1da034ee’: 47, ‘068702351c9d2ff6fe80b55483ee995d9d3d127b’: 47, ‘07fb628cedbff2baa2f0880a934fd5421c2244e6’: 47}}
2017-11-29 19:24:49 - myDevices - INFO - Save History Averages
2017-11-29 19:24:49 - myDevices - INFO - Memory usage : 46 size: 21724
2017-11-29 19:24:49 - myDevices - INFO - Resouce usage info: resource.struct_rusage(ru_utime=181.93, ru_stime=19.67, ru_maxrss=21724, ru_ixrss=0, ru_idrss=0, ru_isrss=0, ru_minflt=431046, ru_majflt=6, ru_nswap=0, ru_inblock=4680, ru_oublock=5512, ru_msgsnd=0, ru_msgrcv=0, ru_nsignals=0, ru_nvcsw=91727, ru_nivcsw=32766)
2017-11-29 19:24:49 - myDevices - INFO - PacketTypes.PT_SYSTEM_INFO
2017-11-29 19:24:50 - myDevices - INFO - PacketTypes.PT_UTILIZATION
2017-11-29 19:25:19 - myDevices - INFO - History CalculateAverages increment: 49
2017-11-29 19:25:19 - myDevices - INFO - Calculate sensor info averages: {‘SensorsInfo’: {‘a12b9a0f4ee53d2fb60542447dde52a49d1c5389’: 48, ‘d4d858ffde48264d728d1698381031fa1da034ee’: 48, ‘068702351c9d2ff6fe80b55483ee995d9d3d127b’: 48, ‘07fb628cedbff2baa2f0880a934fd5421c2244e6’: 48}}
2017-11-29 19:25:19 - myDevices - INFO - Save History Averages
2017-11-29 19:25:20 - myDevices - INFO - Memory usage : 47 size: 21732
2017-11-29 19:25:20 - myDevices - INFO - Resouce usage info: resource.struct_rusage(ru_utime=186.02, ru_stime=20.11, ru_maxrss=21732, ru_ixrss=0, ru_idrss=0, ru_isrss=0, ru_minflt=441653, ru_majflt=6, ru_nswap=0, ru_inblock=4680, ru_oublock=5608, ru_msgsnd=0, ru_msgrcv=0, ru_nsignals=0, ru_nvcsw=93809, ru_nivcsw=33340)
2017-11-29 19:25:20 - myDevices - INFO - PacketTypes.PT_SYSTEM_INFO
2017-11-29 19:25:20 - myDevices - INFO - PacketTypes.PT_UTILIZATION
2017-11-29 19:25:28 - myDevices - INFO - SendHistoryData previously SendFailed items:
2017-11-29 19:25:46 - myDevices - INFO - Checking for updates…
2017-11-29 19:25:49 - myDevices - INFO - Checking update version
2017-11-29 19:25:49 - myDevices - INFO - https://updates.mydevices.com/raspberry/update /etc/myDevices/updates/update
2017-11-29 19:25:49 - myDevices - INFO - Updater retrieve update success
2017-11-29 19:25:49 - myDevices - INFO - History CalculateAverages increment: 50
2017-11-29 19:25:49 - myDevices - INFO - Calculate sensor info averages: {‘SensorsInfo’: {‘a12b9a0f4ee53d2fb60542447dde52a49d1c5389’: 49, ‘d4d858ffde48264d728d1698381031fa1da034ee’: 49, ‘068702351c9d2ff6fe80b55483ee995d9d3d127b’: 49, ‘07fb628cedbff2baa2f0880a934fd5421c2244e6’: 49}}
2017-11-29 19:25:49 - myDevices - INFO - Save History Averages
2017-11-29 19:25:49 - myDevices - INFO - Memory usage : 48 size: 21732
2017-11-29 19:25:49 - myDevices - INFO - Resouce usage info: resource.struct_rusage(ru_utime=190.08, ru_stime=20.58, ru_maxrss=21732, ru_ixrss=0, ru_idrss=0, ru_isrss=0, ru_minflt=452876, ru_majflt=6, ru_nswap=0, ru_inblock=4680, ru_oublock=5712, ru_msgsnd=0, ru_msgrcv=0, ru_nsignals=0, ru_nvcsw=96228, ru_nivcsw=34068)
2017-11-29 19:25:49 - myDevices - INFO - PacketTypes.PT_SYSTEM_INFO
2017-11-29 19:25:50 - myDevices - INFO - PacketTypes.PT_UTILIZATION
2017-11-29 19:25:51 - myDevices - INFO - No new version detected. Closing update…
2017-11-29 19:26:19 - myDevices - INFO - History CalculateAverages increment: 51
2017-11-29 19:26:19 - myDevices - INFO - Calculate sensor info averages: {‘SensorsInfo’: {‘a12b9a0f4ee53d2fb60542447dde52a49d1c5389’: 50, ‘d4d858ffde48264d728d1698381031fa1da034ee’: 50, ‘068702351c9d2ff6fe80b55483ee995d9d3d127b’: 50, ‘07fb628cedbff2baa2f0880a934fd5421c2244e6’: 50}}
2017-11-29 19:26:19 - myDevices - INFO - Save History Averages
2017-11-29 19:26:19 - myDevices - INFO - Memory usage : 49 size: 21736
2017-11-29 19:26:19 - myDevices - INFO - Resouce usage info: resource.struct_rusage(ru_utime=193.95, ru_stime=20.99, ru_maxrss=21736, ru_ixrss=0, ru_idrss=0, ru_isrss=0, ru_minflt=462565, ru_majflt=6, ru_nswap=0, ru_inblock=4680, ru_oublock=5808, ru_msgsnd=0, ru_msgrcv=0, ru_nsignals=0, ru_nvcsw=98259, ru_nivcsw=34545)
2017-11-29 19:26:19 - myDevices - INFO - PacketTypes.PT_SYSTEM_INFO
2017-11-29 19:26:19 - myDevices - INFO - PacketTypes.PT_UTILIZATION
2017-11-29 19:26:28 - myDevices - INFO - SendHistoryData previously SendFailed items:
2017-11-29 19:26:49 - myDevices - INFO - History CalculateAverages increment: 52
2017-11-29 19:26:49 - myDevices - INFO - Calculate sensor info averages: {‘SensorsInfo’: {‘a12b9a0f4ee53d2fb60542447dde52a49d1c5389’: 51, ‘d4d858ffde48264d728d1698381031fa1da034ee’: 51, ‘068702351c9d2ff6fe80b55483ee995d9d3d127b’: 51, ‘07fb628cedbff2baa2f0880a934fd5421c2244e6’: 51}}
2017-11-29 19:26:49 - myDevices - INFO - Save History Averages
2017-11-29 19:26:49 - myDevices - INFO - Memory usage : 50 size: 21736
2017-11-29 19:26:49 - myDevices - INFO - Resouce usage info: resource.struct_rusage(ru_utime=198.2, ru_stime=21.38, ru_maxrss=21736, ru_ixrss=0, ru_idrss=0, ru_isrss=0, ru_minflt=472732, ru_majflt=6, ru_nswap=0, ru_inblock=4680, ru_oublock=5904, ru_msgsnd=0, ru_msgrcv=0, ru_nsignals=0, ru_nvcsw=100288, ru_nivcsw=35020)
2017-11-29 19:26:49 - myDevices - INFO - PacketTypes.PT_SYSTEM_INFO
2017-11-29 19:26:50 - myDevices - INFO - PacketTypes.PT_UTILIZATION
pi@raspberrypi:~ $ telnet cloud.mydevices.com 8181
telnet> quit
Connection closed.
pi@raspberrypi:~ $
How do I paste a screen shot from scrot here?
