I put the code in already and run from my computer and to cayenne . It is not working . I have tried for many times . It dos not work . Please help !
which device are you using and can you share the code?
you are missing Cayenne.begin(username, password, clientID, ssid, wifiPassword);
Also, you should never call Cayenne.virtualWrite from the main loop. You can use inbuilt function CAYENNE_OUT_DEFAULT to send data to cayenne.
here is example code:-
This example shows how to connect to Cayenne using an ESP8266 and send/receive sample data.
Steps:
1. If you have not already installed the ESP8266 Board Package install it using the instructions here: https://github.com/esp8266/Arduino#installing-with-boards-manager.
2. Select your ESP8266 board from the Tools menu.
//#define CAYENNE_DEBUG
char ssid[] = "ssid";
CAYENNE_OUT_DEFAULT()
//Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
