#include <Wire.h> // For I2C communication with sensor
//#include <WiFi101.h> // For connecting to WiFi
#define CAYENNE_PRINT SerialUSB
#include “BMA250.h” // For interfacing with the accel. sensor
#include <CayenneMQTTWiFi101.h> // Cayenne library to connect to transmit data
/*********************** EDIT THIS SECTION TO MATCH YOUR INFO *************************/
// WiFi network information
char ssid = “-”; // your network SSID (name)
char wifiPassword = “-”; // your network password
char username = “-”;
char password = “-”;
char clientID = “-”;
// Accelerometer sensor variables for the sensor and its values
BMA250 accel_sensor;
int x, y, z;
double temp;
SerialUSB.begin(9600);
Wire.begin();
WiFi.setPins(8, 2, A3, -1); // VERY IMPORTANT FOR TINYCIRCUITS WIFI SHIELD
while (!SerialUSB); // Will halt program until the Serial Monitor is opened
// Connect to WiFi and Cayenne
// connectWifi();
// Cayenne.begin(username, password, clientID);
// Set up the BMA250 acccelerometer sensor
// SerialUSB.print(“Initializing BMA…”); SerialUSB.println();
accel_sensor.begin(BMA250_range_2g, BMA250_update_time_64ms);
// Take sensor reading and print to Serial Monitor
accel_sensor.read(); //This function gets new data from the acccelerometer
// Get the acceleration values from the sensor and store them into global variables
// (Makes reading the rest of the program easier)
x = accel_sensor.X;
y = accel_sensor.Y;
z = accel_sensor.Z;
temp = ((accel_sensor.rawTemp * 0.5) + 24.0);
// Call function to display sensor readings on Serial Monitor
showSerial();
// Report sensor reading to Cayenne
delay(2000); // delay before looping again to take new reading
// Prints the sensor values to the Serial Monitor (found under ‘Tools’)
void showSerial() {
SerialUSB.print("X = ");
SerialUSB.print(x);
SerialUSB.print(" Y = ");
SerialUSB.print(y);
SerialUSB.print(" Z = ");
SerialUSB.print(z);
SerialUSB.print(" Temperature(C) = ");
SerialUSB.println(temp);
// This function goes through the steps to connect to WiFi using the WiFi101 library
void connectWifi(void){
// Connect to Wifi network:
SerialUSB.print("Connecting Wifi: ");
SerialUSB.println(ssid);
WiFi.begin(ssid, wifiPassword);
// Loop until connection is secured
while (WiFi.status() != WL_CONNECTED)
SerialUSB.print(“.”);
delay(500);
// Success message and put WiFi in low power mode to save energy
WiFi.maxLowPowerMode();
SerialUSB.println(“”);
SerialUSB.println(“WiFi connected”);
CAYENNE_OUT_DEFAULT()
// Write data to Cayenne here:
Cayenne.virtualWrite(1, x);
Cayenne.virtualWrite(2, y);
Cayenne.virtualWrite(3, z);
Cayenne.virtualWrite(4, temp);
