Chart Scaling
Hi ,wondering if anyone has had issues with history charts and the display scale ?
Some of my devices cant show the full range of readings due to the scale on the chart not matching the range settings on the device.
I have tried changing the range values with no luck , some work fine but others I cant see the upper or lower readings.
Also, they work fine on the phone app , just not on PC either Mac or Windows.
Thanks for reporting this.we will look into this.can you PM me your email id and also the code you are using.
Hi Shramik.
Thanks for the reply .
Below are the codes for the affected devices.
As I mentioned, these work fine on my phone app as do my 6 other
devices.
It just seems to be these particular ones . interestedly the Heat pumps
has 4 working and 2 not.
The code is quite simple which is why I use prefer Cayenne over Blynk
especially with temp sensors.
Regards.
Dave Martin.
1/ POOL TEMP - Channels 1&2 chart issues
//#define CAYENNE_DEBUG
#include <OneWire.h>
char ssid[] = "XXXX";
char wifiPassword[] = "XXXX";
char username[] = "e578fe50-e86d-11e6-a446-0d180dc59d42";
char password[] = "-------------------------------------------------------";
char clientID[] = "5be4a220-bf1c-11e8-a79e-89b0eb263992";
#define VIRTUAL_CHANNEL 3
#define ACTUATOR_PIN 5 // Do not use digital pins 0 or 1 since those conflict with the use of Serial.
#define SENSOR_PIN 4 // Do not use digital pins 0 or 1 since those conflict with the use of Serial.
#define VIRTUAL_CHANNEL_1 1
#define VIRTUAL_CHANNEL_2 2
OneWire oneWire(SENSOR_PIN);
Cayenne.begin(username, password, clientID, ssid,wifiPassword);
sensors.begin();
CAYENNE_IN(VIRTUAL_CHANNEL)
int value = getValue.asInt();
CAYENNE_LOG("Channel %d, pin %d, value %d", VIRTUAL_CHANNEL, ACTUATOR_PIN, value);
CAYENNE_OUT(VIRTUAL_CHANNEL_1)
Cayenne.celsiusWrite(VIRTUAL_CHANNEL_1,sensors.getTempCByIndex(0));
CAYENNE_OUT(VIRTUAL_CHANNEL_2)
Cayenne.celsiusWrite(VIRTUAL_CHANNEL_2,sensors.getTempCByIndex(1));
2/ HEAT PUMP TEMPS - Channels 1 & 6 chart issues
**#define CAYENNE_PRINT Serial // Comment this out to disable prints and save space
can you PM me your email_id?
you might have enabled the graph setting for the line chart, so the default y-axis range is set to 0-20.
to solve the issue:
  • change the widget from gauge to line chart.
  • open setting of the line chart.
  • at the bottom disable the graph setting or adjust the value as required.
  • next change the widget from line chart to gauge.
Hi Shramik.
Thanks for the help .
That has sorted out my issue .
I didn’t realise the range could be changed that way
and now it all looks good.
Again , thank you very much.
Dave
