I’m using a ESP8266 CP2102 Module.
I tried to connect it to cayenne platform, but nothing seems to work.
Can anyone help?
Thank you
Can anyone help?
Thank you
can you share a link to the device you are using.
which code are you using?
The code i’m using:
//#define CAYENNE_DEBUG
char ssid = “ssid”;
char wifiPassword = “wifiPassword”;
char username = “af7ff680-f0fa-11e9-ba7c-716e7f5ba423”;
char password = “02659680d3bf6c2c0d9bd92a713f1bd1159ec0db”;
char clientID = “5d4e3630-3d56-11ea-b301-fd142d6c1e6c”;
unsigned long lastMillis = 0;
CAYENNE_OUT_DEFAULT()
//Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
How can I connect it to a eduroam (university wifi) network?
you need to add your wifi ssid (name) and password.
I did write that information.
I’m trying to connect to my university wifi, eduroam, how can I do it?
you need to add your university wifi ssid and password. thats what i am saying or is there something i am missing here.
My wifi network of my university is EDUROAM.
It uses WPA2-Enterprise and I have to insert my email and password to acess it.
How can I write that in my code, so I can connect?
you need to specific this earlier. there is no support from cayenne to connect to WPA2-enterprise.
Thank you for trying to help
Just to make it clear, there is no ESP8266 support for WPA2 enterprise. This isn’t a Cayenne limitation.
@adam but i had come across recently about some talk where esp8266 can connect, not sure what the progress is now.
Interesting, have any links? Last time I looked it wasn’t possible. If so, he could just connect to wifi manually and use the pubsubclient library.
