1234
Steps:
char ssid[] = "ssid";
char username[] = "";
char password[] = "";
char clientID[] = "";
#define EspSerial Serial1
ESP8266 wifi(&EspSerial);
	delay(10);
	// Set ESP8266 baud rate
	EspSerial.begin(115200);
	delay(10);
CAYENNE_OUT_DEFAULT()
	//Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
can you add more info about what is this about?
