Hey guys, I just learned about IoT, and I’m trying a project using the ESP8266-01 and ArduinoUno R3 modules. This is the scheme that I use :
I have a problem when I want to upload the code from Arduino IDE to the ESP module.
This is the code that I use :
This sketch connects to the Cayenne server using an ESP8266 WiFi module as a shield connected
via a hardware serial to an Arduino.
The CayenneMQTT Library is required to run this sketch. If you have not already done so you can
install it from the Arduino IDE Library Manager.
Steps:
1. Install the ESP8266SerialLibrary.zip library via the Arduino IDE (Sketch->Include Library->Add
.ZIP Library) from the Cayenne extras/libraries
folder (e.g. My Documents\Arduino\libraries\CayenneMQTT\extras\libraries) to compile this
example.
2. Connect the ESP8266 as a shield to your Arduino. This example uses the Serial1 hardware serial
pins available on the Mega. You can also try
6. A temporary widget will be automatically generated in the Cayenne Dashboard. To make the
widget permanent click the plus sign on the widget.
char ssid[] = "arduino";
char wifiPassword[] = "joking77";
char username[] = "xxxxxxxxx";
char password[] = "xxxxxxxxxx";
char clientID[] = "xxxxxxxxxx";
// Set ESP8266 Serial object. In this example we use the Serial1 hardware serial which is available
on boards like the Arduino Mega.
#define EspSerial Serial
ESP8266 wifi(&EspSerial);
delay(10);
// Set ESP8266 baud rate
EspSerial.begin(9600);
delay(10);
// You can also use functions for specific channels, e.g CAYENNE_OUT(1) for sending channel 1
data.
CAYENNE_OUT_DEFAULT()
// Write data to Cayenne here. This example just sends the current uptime in milliseconds on virtual
channel 0.
//Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
//Process message here. If there is an error set an error message using getValue.setError(), e.g
getValue.setError("Error message");
When I try to upload it, it displays an error message. This is the message:
Arduino: 1.8.9 (Windows 10), Board: "Generic ESP8266 Module, 80 MHz, Flash, Disabled, ck, 26
MHz, 40MHz, DOUT (compatible), 512K (no SPIFFS), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200"
<command-line>:0:9: error: expected unqualified-id before numeric constant
C:\Users\Bagus Ramadhan\Documents\Arduino\as\as.ino:35:1: note: in expansion of macro
'ESP8266'
C:\Users\Bagus Ramadhan\Documents\Arduino\as\as.ino: In function 'void setup()':
as:46:47: error: 'wifi' was not declared in this scope
exit status 1
"Show verbose output during compilation"
option enabled in File -> Preferences.
I intend to try turning on the Arduino LED on pin 13 using cayenne, but I have a problem
Can you help me? What should I do? I was a little dizzy and confused because this problem had not been resolved ![]()
