Thanks for the help.
Now i followed this guide instead:(Arduino, MQTT, Cayenne)
It worked little better for me.
Now i can turn on the light for R0 and R1 on my Controllino Maxi Automation.
I use channel 22 and 23.
The Pinout is here: https://www.controllino.biz/wp-content/uploads/2018/12/CONTROLLINO-MAXI-Automation-Pinout-1.jpg
But the strange thing for me now is that the light turns on on R0 and R1 but the Relay is not opend and closed, only the light changes.
I put my code below
#include <SPI.h>
#include <Controllino.h>
Steps:
- Compile and upload the sketch.
- A temporary widget will be automatically generated in the Cayenne Dashboard. To make the widget permanent click the plus sign on the widget.
char username = “#################################”;
char password = "#################################;
char clientID = “#################################”;
#define VIRTUAL_CHANNEL_22 22
#define VIRTUAL_CHANNEL_23 23
#define ACTUATOR_PIN_22 22 // Do not use digital pins 0 or 1 since those conflict with the use of Serial.
#define ACTUATOR_PIN_23 23
pinMode(ACTUATOR_PIN_22, OUTPUT);
pinMode(ACTUATOR_PIN_23, OUTPUT);
CAYENNE_IN(VIRTUAL_CHANNEL_22)
if (getValue.asInt() == 0) {
digitalWrite(ACTUATOR_PIN_22, HIGH);
else {
digitalWrite(ACTUATOR_PIN_22, LOW);
CAYENNE_IN(VIRTUAL_CHANNEL_23)
digitalWrite(ACTUATOR_PIN_23, HIGH);
else {
digitalWrite(ACTUATOR_PIN_23, LOW);
CAYENNE_OUT_DEFAULT()
Cayenne.celsiusWrite(1, 23.0);
Cayenne.luxWrite(2, 700);
Cayenne.virtualWrite(3, 50, TYPE_PROXIMITY, UNIT_CENTIMETER);
CAYENNE_IN_DEFAULT()
