I am using NodeMCU with ArduinoIDE and ESP8266 library for Cayenne.
I am using both Web and iOS Dashboards
I have two issues that I’d like to report for potential bug fixes. The issue relating to signal icon and unit for particle matter readings were reported in other thread.
I have two channels with gauge widget, both sending the same data type using exactly the same command. On the Web Dashboard one of them is displaying properly and as expected, while the other one shows also unit after the value text. Look at PM1 PPM and PM2.5 PPM.
Is there a Dashboard view settings synchronisation between Web and iOS dashboards? What I am experiencing is that even though I have set up humidity, temp and heat index gauge widgets with proper colours and their range values on the Web interface, in an iOS app they seem to reset to some general range. Unfortunately on iOS I can only set min and max value for the gauge and not how the colours should appear in between. Compare first image with the one below from iOS.
