However, when viewing on the mobile app (ios) I get the units as Analog… The graphing is also not correct on the app, but lets start with why my units say Analog. I have tried going to settings and changing them, but after a short period of time it goes back to showing units as “Analog”.
Hi, temperature and humidity works on my end, however I have issue with DSM501A sensor for particle matter.
I am using NodeMCU with Arduino IDE and ESP8266 library for Cayenne. I am sending data to Cayenne using virtualWrite command with data type as “pm” and unit as “mg” as given in Cayenne documentation.
Also according to data type table I should be able to use either value, gauge or graph widgets with this data type but the only one that is working is Value Widget (website but iOS also). I have no option popping up when I click on “Settings” to change it to gauge or graph.
