//##Easy plug & play cheap china esp8266-12E with relay ouput , input state & a cheap LM35 temperature sensor connected on pin ADC ##
// VE2VAX/va2nq sept-2018
// exemple avec un relai + un input + sonde temperature LM35 sur pin ADC
#define CAYENNE_DEBUG
#define CAYENNE_PRINT serial
#define DIGITAL_PIN 5 //INPUT SWITCH
int inPin = 5;
int lm35 = 0;
int Clm35 = 0;
int vref = 1; //analog voltage reference ( 1 volt ou 3.3 volts ) sur le esp8266-E12 c'est 1 volt
char ssid[] = "ve2vax";
char wifiPassword[] = "12345678";
char username[] = "3xxxxxx-xxxxxx-xxxxxxxxx";
char password[] = "5xxxxxxxxx-xxxxxxxxx-xxxxxxxxx";
char clientID[] = "xxxxx-xxxxxxxx-xxxxxxx-xxxx";
pinMode(2, OUTPUT);
digitalWrite(2, LOW);
pinMode(5, INPUT_PULLUP); // pin input
pinMode(4, OUTPUT);
digitalWrite(4, LOW);
delay(2500); // # milli secondes de delais
// These functions are called when the Cayenne widget requests data for the Virtual Pin.
CAYENNE_OUT(0)
int val = digitalRead(inPin); // read the input pin
Cayenne.virtualWrite(DIGITAL_PIN , val);
CAYENNE_OUT(1)
float lm35 = (((vref * analogRead(A0) * 100.0) / 1023) - 1.3); // read adc input pin LM35 = 10mv/C
// la valeur 1.3 est la valeur de correction de temperature
Cayenne.virtualWrite(1 , lm35);
CAYENNE_IN(6)
if (currentValue == 1)
//do whatever you want when you turn on the button on cayenne dashboard
digitalWrite(2, HIGH);
else
//do whatever you want when you turn off the button on cayenne dashboard
CAYENNE_IN(8)
digitalWrite(4, HIGH);
else
Thanks for sharing this.
A suggestion you can delete the delay in the main loop.
I want to try this project but i need your help.
Can you send me the schematic for this project, please?
I am new here and i dont know which pins to use for relay and LM35.
Waiting for your reply.
Here it is. lm35 is connected to A0 pin.
is the relay.
