it comes with multiply errors when checking the code
i can find the correct order
char ssid =
char wifiPassword =
char username =
char password =
char clientID =
#define VIRTUAL_CHANNEL 6
#define ACTUATOR_PIN 4 // Do not use digital pins 0 or 1 since those conflict with the use of Serial.
int ledPin = 2;
pinMode(ledPin, OUTPUT);
int value = 0;
// constants won’t change. Used here to set a pin number:
const int ledPin = LED_BUILTIN;// the number of the LED pin
// Variables will change:
int ledState = LOW; // ledState used to set the LED
// Generally, you should use “unsigned long” for variables that hold time
// The value will quickly become too large for an int to store
unsigned long previousMillis = 0; // will store last time LED was updated
// constants won’t change:
const long interval = 1000;
void loop(){
if (value == 1)
if (currentMillis - previousMillis >= interval) {
// save the last time you blinked the LED
// if the LED is off turn it on and vice-versa:
if (ledState == LOW) {
ledState = HIGH;
} else {
ledState = LOW;
// set the LED with the ledState of the variable:
digitalWrite(ledPin, ledState);
CAYENNE_IN(VIRTUAL_CHANNEL)
value = getValue.asInt();
