#include <WiFi101.h>
#include <Firmata.h>
#include <RTCZero.h>
#include "utility/SerialFirmata.h"
#include <ArduinoJson.h>
#define WIFI_MAX_CONN_ATTEMPTS 3
#define SERVER_PORT 3030 //port for firmata
/*/custom sysex commands used for
//test connection is up by switching led on/off
//Do a refresh of data outside the normal cycle
//Set the inverter mode - Utility,Solar or SBU */
#define TEST_MODE 0x40
#define RELOAD_NOW 0x41
#define SET_MOD 0x42
///*** WiFi Network Config ***///
char ssid[] = "<your wifi ssid>"; // your network SSID (name)
char pass[] = "<your password>"; // your network password (use for WPA, or use as key for WEP)
///*** Azure IoT Hub Config ***///
char hostname[] = "<your host here>.azure-devices.net"; // host name address for your Azure IoT Hub
char authSAS[] = "SharedAccessSignature sr=<your host here>.azure-devices.net%2fdevices%2f<your device>&sig=your key here>";
String azureReceive = "/devices/<your device>/messages/devicebound?api-version=2016-02-03";
char feeduri[] = "/devices/<your device>/messages/devicebound?api-version=2016-02-03"; //feed URI
char azurePOST_Uri[]= "/devices/<your device>/messages/events?api-version=2016-02-03"; // feed POST Uri
unsigned long lastConnectionTime = 0;
RTCZero rtc;
//SerialFirmata serialFeature; //enable
int wifiConnectionAttemptCounter = 0;
int wifiStatus = WL_IDLE_STATUS;
int last_request;
int serial_time_out = 10;
//String inData; // global string to hold the inverter answer
const int MKR_LED = 6;
const int MKR_WIFI = 0;
const int MKR_INFO = 1;
int wait_cycle = 60; // set the cycle time in seconds autmatic update will happen every wait_cycle seconds
boolean isResetting = false;
signed char queryIndex = -1;
/* timer variables */
unsigned long currentMillis; // store the current value from millis()
unsigned long previousMillis; // for comparison with currentMillis
//Device commands with 2 CRC bytes
String QPIGS = "\x51\x50\x49\x47\x53\xB7\xA9\x0D";
String QPIWS = "\x51\x50\x49\x57\x53\xB4\xDA\x0D";
String QDI = "\x51\x44\x49\x71\x1B\x0D";
String QMOD = "\x51\x4D\x4F\x44\x49\xC1\x0D";
String QVFW = "\x51\x56\x46\x57\x62\x99\x0D";
String QVFW2 = "\x51\x56\x46\x57\x32\xC3\xF5\x0D";
String POP02 = "\x50\x4F\x50\x30\x32\xE2\x0B\x0D"; //SBU priority
String POP01 = "\x50\x4F\x50\x30\x32\xE2\xD2\x69"; //solar first
String POP00 = "\x50\x4F\x50\x30\x30\xC2\x48\x0D"; //utility first
* setup
void systemResetCallback()
isResetting = true;
// initialize a defalt state
// TODO: option to load config from EEPROM instead of default
for (byte i = 0; i < TOTAL_PINS; i++) {
// pins with analog capability default to analog input
// otherwise, pins default to digital output
if (IS_PIN_ANALOG(i)) {
// turns off pullup, configures everything
//tPinModeCallback(i, PIN_MODE_ANALOG);
} else if (IS_PIN_DIGITAL(i)) {
// sets the output to 0, configures portConfigInputs
//etPinModeCallback(i, OUTPUT);
pinMode(MKR_LED, OUTPUT);
pinMode(MKR_INFO, OUTPUT);
pinMode(MKR_WIFI, OUTPUT);
* FIRMATA SETUP
Firmata.setFirmwareVersion(FIRMATA_FIRMWARE_MAJOR_VERSION, FIRMATA_FIRMWARE_MINOR_VERSION);
Firmata.attach(STRING_DATA, stringCallback);
Firmata.attach(SYSTEM_RESET, systemResetCallback);
Firmata.attach(START_SYSEX, sysexCallback);
// start up Network Firmata:
connect_wifi();
printWifiStatus();
rtc.begin(); // initialize RTC
Serial.begin(2400);
Serial1.begin(2400);
Serial1.setTimeout(100);
last_request=rtc.getEpoch()-wait_cycle; //set last update request time to the past so updates run directly after reset.
//testblink(MKR_LED,MKR_WIFI,MKR_INFO,200,5);
//read_QVFW();
// read_QVFW2();
* Main loop
/* STREAMREAD - processing incoming messagse as soon as possible, while still checking digital inputs. */
if ( WiFi.status() == 3 )
while (Firmata.available())
digitalWrite(MKR_INFO,HIGH);
Firmata.processInput();
stream.maintain();
else
ledblink(MKR_LED, 500, 4);
connect_wifi();
//Serial.println(WiFi.status());
printWifiStatus();
delay(500);
if (last_request + wait_cycle < rtc.getEpoch()) //Run every wait_cycle seconds
last_request = rtc.getEpoch();
read_QMOD();
read_QPIGS();
//read_QPIWS();
String x;
root.printTo(x);
Firmata.sendString(x.c_str());
//digitalWrite(MKR_INFO,LOW);
Serial.println(x.c_str());
//if (connect_wifi()) {
// ledblink(MKR_LED, 500, 4);
azureHttpPOST(x);
JsonObject& root = jsonBuffer.createObject();
//******************* Open WiFi connection ****************/
int connect_wifi()
WiFi.disconnect();
//ledblink(MKR_WIFI, 100, 10);
while ( WiFi.status() != 3)
wifiStatus = stream.begin(ssid, pass, SERVER_PORT);
ledblink(MKR_WIFI, 500, 4);
delay(3000); // TODO - determine minimum delay
if (++wifiConnectionAttemptCounter > WIFI_MAX_CONN_ATTEMPTS) break;
Firmata.begin(stream);
systemResetCallback(); // reset to default config
return 1;
//******************* get the current time ****************/
uint32_t getNow()
return rtc.getEpoch();
//******************* send a QPIGS command to inverter and store values ****************/
//'(227.0 50.1 240.0 50.2 0490 0451 011 438 53.70 002 100 0044 0002 097.5 53.94 000 00 00010110 00 00 00129 110]I',
void read_QPIGS(){
int end_time;
end_time = serial_time_out + rtc.getEpoch();
Serial1.print(QPIGS);
while (Serial1.available() == 0 && rtc.getEpoch()< end_time) ///wait for answer or timeout
if (Serial1.find("(")) {
root["INP_VOLT"] = Serial1.parseFloat(); //QPIGS.1 Grid voltage
root["INP_FREQ"] = Serial1.parseFloat(); //QPIGS.2 Grid frequency
root["OUT_VOLT"] = Serial1.parseFloat(); //QPIGS.3 Out voltage
root["OUT_FREQ"] = Serial1.parseFloat(); //QPIGS.4 Out frequency
root["OUT_LOAD_VA"] = Serial1.parseInt(); //QPIGS.5 AC output apparent power
root["OUT_LOAD_W"] = Serial1.parseInt(); //QPIGS.6 AC output active power
root["OUT_LOAD_PERC"] = Serial1.parseInt(); //QPIGS.7 Output load percent
Serial1.parseInt(); //skip
root["INP_BAT_VOLT"] = Serial1.parseFloat(); //QPIGS.9 Battery voltage
root["INP_CHG_AMP"] = Serial1.parseInt(); //QPIGS.10 Battery charging current
root["BATT_LEVEL_PERC"] = Serial1.parseInt(); //QPIGS.11 Battery capacity
root["INP_PV_VOLT"] = Serial1.parseFloat(); //QPIGS.14 PV Input voltage
root["OUT_DISC_AMP"] = Serial1.parseInt(); //QPIGS.16 Battery discharge current
////******************* send a QDI command to inverter and store values ****************/
//void read_QDI(){
// int end_time;
// end_time = serial_time_out + rtc.getEpoch();
// Serial1.print(QDI);
// while (Serial1.available() == 0 && rtc.getEpoch()< end_time ) ///wait for answer or timeout
// //Serial.setTimeout(10);
// //while (Serial.available() == 0 && rtc.getEpoch()< end_time ) ///wait for answer
// //while (Serial1.available() == 0 && rtc.getEpoch()< end_time ) ///wait for answer
// // ledblink(MKR_LED, 200, 4);
// //if (Serial.find("(")) {
// if (Serial1.find("(")) {
// Serial.println('qdi');
// //root["OUT_VOLT"] = Serial.parseFloat(); //QDI.1 AC output voltage
// //root["OUT_FREQ"] = Serial.parseFloat(); //QDI.2 AC output frequency
// root["OUT_VOLT"] = Serial1.parseFloat(); //QDI.1 AC output voltage
// root["OUT_FREQ"] = Serial1.parseFloat(); //QDI.2 AC output frequency
//******************* send a QPIWS command to inverter and store values ****************/
void read_QPIWS(){
String inData;
int end_time;
//ledblink(MKR_LED, 500, 3);
Serial1.print(QPIWS);
inData= Serial1.readStringUntil('\r');
//while (Serial1.available() > 0)
// char recieved = Serial1.read();
// inData += recieved;
root["I_SETTING"] = inData.substring(1,30);
//******************* send a QMOD command to inverter and store values ****************/
void read_QMOD(){
String inData;
int end_time;
Serial1.print(QMOD);
root["MODE_MAINS"] = inData.substring(1,2);
//******************* send a QVFW command to inverter and store CPU software version ****************/
void read_QVFW(){
String inData;
int end_time;
Serial1.print(QVFW);
//inData= Serial1.readStringUntil('\r');
inData += recieved;
if (inData.substring(1,3) != "NAK" && inData.substring(0,1) != "" ){
root["CPU_VERSION"] = inData.substring(1,13);
else
root["CPU_VERSION"] = "VERFW:?????.??";
//******************* send a QVFW2 command to inverter and store CPU2 software version ****************/
void read_QVFW2(){
String inData;
int end_time;
Serial.println("1a");
Serial1.print(QVFW2);
Serial.println("2a");
inData += recieved;
Serial.print(".");
Serial.print(inData);
Serial.println(".");
root["CPU2_VERSION"] = inData.substring(1,13);
else
root["CPU2_VERSION"] = "VERFW:?????.??";
//******************* send data to Azure ****************/
void azureHttpPOST(String content) {
// close any connection before send a new request.
// This will free the socket on the WiFi shield
client.stop();
// if there’s a successful connection:
if (client.connect(hostname, 443)) {
//make the GET request to the Azure IOT device feed uri
client.print("POST "); //Do a GET
client.print(azurePOST_Uri); // On the feedURI
client.println(" HTTP/1.1");
client.print("Host: ");
client.println(hostname); //with hostname header
client.print("Authorization: ");
client.println(authSAS); //Authorization SAS token obtained from Azure IoT device explorer
client.println("Connection: close");
client.println("Content-Type: text/plain");
client.print("Content-Length: ");
client.println(content.length());
client.println();
client.println(content);
client.println();
// note the time that the connection was made:
lastConnectionTime = millis();
else {
// if you couldn’t make a connection:
//******************* blink all three leds testmode ****************/
void testblink(int portnum, int portnum1, int portnum2,int timedelay, int flashnum) {
for(int i = 0 ; i < flashnum ; i++){
digitalWrite(portnum, LOW);
digitalWrite(portnum1, LOW);
digitalWrite(portnum2, LOW);
delay(timedelay);
digitalWrite(portnum, HIGH);
digitalWrite(portnum1, HIGH);
digitalWrite(portnum2, HIGH);
delay(timedelay);
//******************* blink a led ****************/
void ledblink(int portnum, int timedelay, int flashnum) {
delay(timedelay);
delay(timedelay);
//******************* stringCallback ****************/
void stringCallback(char *myString)
Serial.println(myString);
//Firmata.sendString(myString);
//******************* setPinValueCallback ****************/
void setPinValueCallback(byte pin, int value)
if (pin < TOTAL_PINS && IS_PIN_DIGITAL(pin)) {
if (Firmata.getPinMode(pin) == OUTPUT) {
Firmata.setPinState(pin, value);
digitalWrite(PIN_TO_DIGITAL(pin), value);
//******************* printWifiStatus ****************/
void printWifiStatus() {
if ( WiFi.status() != WL_CONNECTED )
digitalWrite(MKR_WIFI, LOW);
else
digitalWrite(MKR_WIFI, HIGH);
/* process sysex commands
void sysexCallback(byte command, byte argc, byte *argv)
byte mode;
byte stopTX;
byte slaveAddress;
byte data;
int slaveRegister;
unsigned int delayTime;
switch (command) {
case TEST_MODE:
if( argc == 1 ) //verify we received the whole message
//the MSB is always sent in the LSB position 2nd byte
byte val;
if( argv[0] == 1 )
val = HIGH;
else
val = LOW;
digitalWrite( MKR_LED, val );
Firmata.write(END_SYSEX);
break;
case SET_MOD:
Serial.println("SET_MOD");
if (argc == 1) //verify we received the whole message
byte val;
switch (argv[0]) {
case 0:
Serial1.print(POP00);
break;
case 1:
break;
case 2:
break;
break;
case RELOAD_NOW:
Serial.println("RELOAD_NOW");
read_QMOD();
read_QPIGS();
read_QPIWS();
String x;
root.printTo(x);
break;
