what?!
first you need get data from the inverter then only you can send it to cayenne.
#include <Firmata.h>
#include <ArduinoJson.h>
#include "utility/SerialFirmata.h"
#define TEST_MODE 0x40
#define RELOAD_NOW 0x41
#define SET_MOD 0x42
unsigned long lastMillis=0;
unsigned long lastMillis1=0;
String QPIGS = "\x51\x50\x49\x47\x53\xB7\xA9\x0D";
String QPIWS = "\x51\x50\x49\x57\x53\xB4\xDA\x0D";
String QDI = "\x51\x44\x49\x71\x1B\x0D";
String QMOD = "\x51\x4D\x4F\x44\x49\xC1\x0D";
String QVFW = "\x51\x56\x46\x57\x62\x99\x0D";
String QVFW2 = "\x51\x56\x46\x57\x32\xC3\xF5\x0D";
char username[] = "
char password[] = "
char clientID[] = "
String POP02 = "\x50\x4F\x50\x30\x32\xE2\x0B\x0D"; //SBU priority
String POP01 = "\x50\x4F\x50\x30\x32\xE2\xD2\x69"; //solar first
String POP00 = "\x50\x4F\x50\x30\x30\xC2\x48\x0D"; //utility first
StaticJsonBuffer<300> jsonBuffer;
JsonObject& root = jsonBuffer.createObject();
boolean isResetting = false;
signed char queryIndex = -1;
unsigned long currentMillis; // store the current value from millis()
unsigned long previousMillis; // for comparison with currentMillis
void systemResetCallback()
isResetting = true;
// initialize a defalt state
// TODO: option to load config from EEPROM instead of default
for (byte i = 0; i < TOTAL_PINS; i++) {
// pins with analog capability default to analog input
// otherwise, pins default to digital output
if (IS_PIN_ANALOG(i)) {
// turns off pullup, configures everything
//tPinModeCallback(i, PIN_MODE_ANALOG);
} else if (IS_PIN_DIGITAL(i)) {
// sets the output to 0, configures portConfigInputs
//etPinModeCallback(i, OUTPUT);
Serial1.begin(2400);
// Serial1.begin(2400);
Firmata.setFirmwareVersion(FIRMATA_FIRMWARE_MAJOR_VERSION, FIRMATA_FIRMWARE_MINOR_VERSION);
Firmata.attach(STRING_DATA, stringCallback);
Firmata.attach(SYSTEM_RESET, systemResetCallback);
Firmata.attach(START_SYSEX, sysexCallback);
Serial.println("finito setup");
{ Cayenne.loop();
CAYENNE_OUT_DEFAULT()
Serial.println ("invio a cayenne");
//Cayenne.luxWrite(2, 700);
CAYENNE_IN_DEFAULT()
void sysexCallback(byte command, byte argc, byte *argv)
byte mode;
byte stopTX;
byte slaveAddress;
byte data;
int slaveRegister;
unsigned int delayTime;
switch (command) {
case TEST_MODE:
if( argc == 1 ) //verify we received the whole message
//the MSB is always sent in the LSB position 2nd byte
byte val;
if( argv[0] == 1 )
val = HIGH;
else
val = LOW;
Firmata.write(END_SYSEX);
break;
case SET_MOD:
Serial.println("SET_MOD");
if (argc == 1) //verify we received the whole message
byte val;
switch (argv[0]) {
case 0:
Serial1.print(POP00);
break;
case 1:
break;
case 2:
break;
break;
case RELOAD_NOW:
Serial.println("RELOAD_NOW");
//read_QMOD();
//read_QPIGS();
//read_QPIWS();
String x;
root.printTo(x);
Firmata.sendString(x.c_str());
break;
void setPinValueCallback(byte pin, int value)
if (pin < TOTAL_PINS && IS_PIN_DIGITAL(pin)) {
if (Firmata.getPinMode(pin) == OUTPUT) {
Firmata.setPinState(pin, value);
void stringCallback(char *myString)
Serial.println(myString);
//Firmata.sendString(myString);
questo è il codice che ho prodotto, ma niente, non comunica con la com
As i said, you need to first get data from the inverter. there are several factors that can go wrong here as the RS232 to TTL converter you have build is not working properly. you will need to solve this issue and try to get data from the inverter.
Hi, I managed to solve the hardware problem Arduino side, with a TTL RS232 port from PC you see that it prints the necessary, but the inverter does not respond.
well it looks like an issue with your inverter.
funziona alla grande
What exactly is the problem?
hardware, I had not calculated that in the connection board rs232-ttl on the inverter side rx-tx they had to be reversed, the code works perfectly for those who want to use
Awesome, nice job!
it would be great if you would make a detailed tutorial on how to send inverter data to cayenne.
long previousMillis = 0;
long interval = 1000;
char username[] = "f";
char password[] = "";
char clientID[] = "";
float imp_volt;
float imp_freq;
float out_volt;
float out_freq;
int out_load_va;
int out_load_w;
int out_load_perc;
float bat_volt;
int chg_amp;
int batt_level_perc;
float pv_amp;
float pv_volt;
int disc_amp;
int inv_temp;
float W_ftv;
String stato;
int readvalue;
Serial.println("finito setup2");
void loop(){
if (currentMillis - previousMillis > interval) {
Serial.println("ciclo if e stampo json");
read_QMOD();
read_QPIGS();
String x;
root.printTo(x);
Serial.println(x.c_str());
imp_volt=root["INP_VOLT"];
imp_freq=root["INP_FREQ"] ;
out_volt=root["OUT_VOLT"];
out_freq=root["OUT_FREQ"];
out_load_va=root["OUT_LOAD_VA"];
out_load_w=root["OUT_LOAD_W"];
out_load_perc= root["OUT_LOAD_PERC"];
bat_volt=root["INP_BAT_VOLT"];
chg_amp=root["INP_CHG_AMP"];
batt_level_perc=root["BATT_LEVEL_PERC"];
pv_amp=root["INP_PV_amp"];
pv_volt=root["INP_PV_amp2"];
disc_amp=root["OUT_DISC_AMP"];
inv_temp=root["inv_temp"];
W_ftv=( pv_volt*pv_amp);
Serial.print("stato=");
Serial.println(stato);
Cayenne.virtualWrite(1,imp_volt,"voltage","v");
Cayenne.virtualWrite(2,imp_freq,"freq","hz");
Cayenne.virtualWrite(3,out_volt,"voltage","v");
Cayenne.virtualWrite(4,out_freq,"freq","hz");
Cayenne.virtualWrite(5,out_load_va,"pow","w");
Cayenne.virtualWrite(6,out_load_w,"pow","w");
Cayenne.virtualWrite(7,out_load_perc);
Cayenne.virtualWrite(8, bat_volt,"batt","v");
Cayenne.virtualWrite(9,chg_amp,"current","a");
Cayenne.virtualWrite(10,batt_level_perc,"batt","p");
Cayenne.virtualWrite(11,pv_volt,"voltage","v");
Cayenne.virtualWrite(12,disc_amp);
Cayenne.virtualWrite(14,pv_amp,"current","a");
Cayenne.celsiusWrite(15,inv_temp);
Cayenne.virtualWrite(16,W_ftv,"pow","w");
if (stato==("B")) {
Cayenne.virtualWrite(13,1,"digital_sensor","d");
Serial.println("led acceso");}
else
{Serial.println("led spento");
Cayenne.virtualWrite(13,0,"digital_sensor","d");}
void read_QPIGS()
Serial1.print(QPIGS);
while (Serial1.available() == 0 ) ///wait for answer or timeout
if (Serial1.find("(")) {
Serial.println("provo a stampa dalla seriale 1");
root["INP_VOLT"] = Serial1.parseFloat(); //QPIGS.1 Grid voltage
root["INP_FREQ"] = Serial1.parseFloat(); //QPIGS.2 Grid frequency
root["OUT_VOLT"] = Serial1.parseFloat(); //QPIGS.3 Out voltage
root["OUT_FREQ"] = Serial1.parseFloat(); //QPIGS.4 Out frequency
root["OUT_LOAD_VA"] = Serial1.parseInt(); //QPIGS.5 AC output apparent power
root["OUT_LOAD_W"] = Serial1.parseInt(); //QPIGS.6 AC output active power
root["OUT_LOAD_PERC"] = Serial1.parseInt(); //QPIGS.7 Output load percent
root["INP_nonso"]=Serial1.parseInt(); //skip
root["INP_BAT_VOLT"] = Serial1.parseFloat(); //QPIGS.9 Battery voltage
root["INP_CHG_AMP"] = Serial1.parseInt(); //QPIGS.10 Battery charging current
root["BATT_LEVEL_PERC"] = Serial1.parseInt(); //QPIGS.11 Battery capacity
root["inv_temp"] =Serial1.parseInt(); //skip
root["INP_PV_amp"] =Serial1.parseFloat(); //skip
root["INP_PV_amp2"] =Serial1.parseFloat(); //QPIGS.14 PV Input voltage
root["INP_PV_VOLT121"] = Serial1.parseFloat(); //skip
root["OUT_DISC_AMP"] = Serial1.parseInt(); //QPIGS.16 Battery discharge current
void read_QPIWS(){
String inData;
//ledblink(MKR_LED, 500, 3);
Serial1.print(QPIWS);
while (Serial1.available() == 0&& millis()< lastMillis+1000) ///wait for answer or timeout
inData= Serial1.readStringUntil('\r');
//while (Serial1.available() > 0)
// char recieved = Serial1.read();
// inData += recieved;
root["I_SETTING"] = inData.substring(1,30);
void read_QMOD(){
{Serial1.flush();
byte a=Serial1.read();}
String inData;
Serial1.print(QMOD);
root["MODE_MAINS"] = inData.substring(1,2);
stato= inData.substring(1,2);
a tutorial I don’t even know where to start, I’m not good or competent like many who hang out on the forum …
pro to describe the code very quickly …
I used the json library which fortunately is already part of the work and used arduino 2. an rs232-ttl interface and an etherne cable where I connected to the inverter mpp solar as specified by the manufacturer (rx-tx-gnd pin 1 and 2 and 5 of the ethernet plug.
I declared the support variables for sending to cayenne and copied the values from the json library … in practice qnd sends the qpigs command to the inverter he replies with a string of raw data that by copying are the jobs you need (power, voltage ,current)
for those who like me like I have practically gone crazy to succeed, I really hope to be able to give a valid hand to the forum in my small way … then if you have ideas for improvement I am open to everything … for now it does its job well.
I am always waiting for an implementation of dialogue between devices.
in the sense I have too much production I would like to have a resistive load attached, but only if there is nothing else connected, but I can only know by interpolating values from different arduino …
A tutorial as a new topic in the community with a attractive topic and some few details like what is the project about, hardware used, circuit diagram code and anything important that need to be added. Once done we can also share your project on cayenne social media.
the hardware for technical reasons and speed / power and availability of 3 serial I used an arduino 2 and an ethernet shield, but it also works with nodecu, but in my opinion it occupies too many resources with the Softwareserial library.
connected tx1 / rx1 to the rs232-ttl card (https://www.ebay.it/i/153202774298?chn=ps),
then if you want other things let me know because I have not but never made a tutorial … I’m excited
i am excited too to see the tutorial and get a chance to make a similer project
how do you want the tutorial to be done
tutorial as in where people can have a look at your post and do their project. which provide them with the necessary instruction to complete the project.
What an excellent script Massimotruglio83 !
Grazie mille!!!
You saved me a lot of time.
I tried your script but I have problem connecting to my 2424 MSXE anyway . Probably a hardware problem. I double checked the cable wiring… I hope to find a solution soon to enjoy your code
figurati e grazie per i complimenti, il cablaggio controllalo bene e ricorda TX RX rovesciati quando ti colleghi, io pure cio sbattuto un sacco di tempo
