I try to remove the location from my project. But I’m not able to change the location (now set to Physical Address). I’m not interested in a map of my location on the Cayenne Dashboard.
the map is added by default. If you dont want it to be shown, then create a new project, then drag and drop the required widgets into the project dashboard Cayenne Docs
Thanks! Is working GREAT!
