Is there a way to delete individual records from the Cayenne web app? The first record of my tracking data has a 0,0 position which throws the map off. I suspect it will eventually drop off, but I would like to delete it.
can you PM me you email_id used for cayenne login, will check if i can delete the data.
what is the time period you want to delete the data?
Thank you for your kind offer. It appears the record has dropped off, so the map shows correctly now.
