I would like connect LORAWAN with Cayenne
I would like to connect LORAWAN with Cayenne.
I have this devices:
I’ve already linked, but maybe I can not choose the right device, because it does not work and I can not even delete this project.
DevEUI is 1243567697550044
Thanks for the answers
Franc
which network server are you using to connect your lora device?
I’m picking out the first one:
1M2M ED 1608
which one should I choose?
1M2M ED 1608 is the device in the network list. check this Cayenne | The Things Network and arduino-device-lib/CayenneLPP.ino at master · TheThingsNetwork/arduino-device-lib · GitHub
Thanks for the reply.
I’ll look at the proposed one.
I can not delete it 1M2M ED 1608 the device in the network list.
can you direct message me your email_id.
