Hello, I’m a beginner in this world of IoT. I’m using Pycom products to learn, they are: Lopy4 (Gateway) and Fipy (node). I am using some sensors too: BME280, HC-SR04, RTC… (But I haven’t set it up yet)
My progress: I can send node data to the gateway through the community sample codes. I already have an application on TTN and already added my gateway (Dev EUI) on cayenne (Lora → The Things Network).
My node (fipy) has the codes:
→ abp_node_USP915.py
→ config.py
My gateway (Lopy4) has the codes:
→ config.py
→ main.py
→ nanogateway.py
(All the code I’m using, I adapted from the pycom libraries.)
Thanks for the answer. I performed this step successfully. Now I need to register Device EUI from my node in cayenne. Then I need to package my node data in CayenneLPP format, right?
First, you need to add the cayenne LPP format payload in your node and then add the DevEUI into cayenne by selecting the appropriate device from the list.
Hi shrink salgaonkar, I have successfully sent the data in cayenneLPP format. Thanks for helping me with this. However, I can’t keep updating the data.
