Hi, I am using the sensor Dragino LSE 01 SOIL Moisture
How Can I program it into cayenne platform? I have this code in TTN
This is the code that I have in my PAYLOAD FORMATS
function Decoder(bytes, port) {
// Decode an uplink message from a buffer
// (array) of bytes to an object of fields.
var value=(bytes[0]<<8 | bytes[1]) & 0x3FFF;
var batV=value/1000;//Battery,units:V
value=bytes[2]<<8 | bytes[3];
if(bytes[2] & 0x80)
{value |= 0xFFFF0000;}
var temp_DS18B20=(value/10).toFixed(2);//DS18B20,temperature,units:℃
value=bytes[4]<<8 | bytes[5];
var water_SOIL=(value/100).toFixed(2);//water_SOIL,Humidity,units:%
value=bytes[6]<<8 | bytes[7];
var temp_SOIL;
if((value & 0x8000)>>15 === 0)
temp_SOIL=(value/100).toFixed(2);//temp_SOIL,temperature,units:°C
else if((value & 0x8000)>>15 === 1)
temp_SOIL=((value-0xFFFF)/100).toFixed(2);//temp_SOIL,temperature,units:°C
value=bytes[8]<<8 | bytes[9];
var conduct_SOIL=(value);//conduct_SOIL,conductivity,units:uS/cm
return {
Bat:batV +" V",
TempC_DS18B20:temp_DS18B20+" °C",
water_SOIL:water_SOIL+" %“,
temp_SOIL:temp_SOIL+” °C",
conduct_SOIL:conduct_SOIL+" uS/cm"
This is the data that I can see in TTN,
However I have connected this device to Cayenne my device, and this doesn’t show any information at all.
What code do I need for this sensor to use in cayenne?
The code that I can see that you recomended is in C++, and in TTN this is not acepted,
class CayenneLPP {
public:
CayenneLPP(uint8_t size);
~CayenneLPP();
void reset(void);
uint8_t getSize(void);
uint8_t* getBuffer(void);
uint8_t copy(uint8_t* buffer);
uint8_t addDigitalInput(uint8_t channel, uint8_t value);
uint8_t addDigitalOutput(uint8_t channel, uint8_t value);
uint8_t addAnalogInput(uint8_t channel, float value);
uint8_t addAnalogOutput(uint8_t channel, float value);
