Here I am again. I have an application sending temperature, pressure and digital signal (NO / NC). However, I tried to add a signal from a cayenneLPP format ultrasonic sensor but it didn’t work. How can I solve this problem, is it related to the data size or socket?
The code below is the configuration of LoraWAN and cayenne LPP along with shipping packages.
# remove all the channels
for channel in range(0, 72):
lora.remove_channel(channel)
# set all channels to the same frequency (must be before sending the OTAA join request)
lora.add_channel(channel, frequency=config.LORA_FREQUENCY, dr_min=0, dr_max=3)
# join a network using ABP (Activation By Personalization)
lora.join(activation=LoRa.ABP, auth=(dev_addr, nwk_swkey, app_swkey))
# create a LoRa socket
s = socket.socket(socket.AF_LORA, socket.SOCK_RAW)
# set the LoRaWAN data rate
s.setsockopt(socket.SOL_LORA, socket.SO_DR, config.LORA_NODE_DR)
# make the socket non-blocking
s.setblocking(False)
# creating Cayenne LPP packet
lpp = cayenneLPP.CayenneLPP(size = 100, sock = s)
while True:
# Receiving fifteen temperature and pressure readings.
bmet = [] # Lista com as temperaturas lidas com o BME280
bmep = [] # Lista com as umiadades lidas com o BME280
numreadings = 15
samples_temperature = [0.0]*numreadings; mean_temperature = 0.0
samples_pressure = [0.0]*numreadings; mean_pressure = 0.0
samples_humidity = [0.0]*numreadings; mean_humidity = 0.0
for i in range (numreadings):
samples_temperature[i], samples_pressure[i], samples_humidity[i] = bme.values
mean_temperature = sum(samples_temperature)/len(samples_temperature)
mean_pressure = sum(samples_pressure)/len(samples_pressure)
t = mean_temperature
p = mean_pressure/100 # Pa -> hectoPa
bmet.append(t)
bmep.append(p)
print("Temperatura:",t, "C e Pressao: ",p, "hPa")
# Receiving the average distance of the function.
distance = distance_median()
print("Distance: ", distance)
# Packaging the data in cayenneLPP format
lpp.add_digital_input(distance, channel = 116)
lpp.send(reset_payload = True)
lpp.add_temperature(bmet[0])
lpp.add_barometric_pressure(bmep[0])
if pm1.value() == False and pm2.value() == False and pm3.value() == False and pm4.value() == False:
print("Nivel atingiu 4 metros!")
lpp.add_digital_input(True)
lpp.add_digital_input(True, channel = 112)
lpp.add_digital_input(True, channel = 113)
lpp.add_digital_input(True, channel = 114)
if pm1.value() == False and pm2.value() == False and pm3.value() == False and pm4.value() == True:
print("Nivel atingiu 3 metros!")
lpp.add_digital_input(False, channel = 114)
if pm1.value() == False and pm2.value() == False and pm3.value() == True and pm4.value() == True:
print("Nivel atingiu 2 metros!")
lpp.add_digital_input(False, channel = 113)
if pm1.value() == False and pm2.value() == True and pm3.value() == True and pm4.value() == True:
print("Nivel atingiu 1 metros!")
lpp.add_digital_input(False, channel = 112)
if pm1.value() == True and pm2.value() == True and pm3.value() == True and pm4.value() == True:
print("Nivel abaixo do normal!")
lpp.add_digital_input(False)
time.sleep(60)
Img ERROR:
