I have this project that I am trying to recreate and the automation is not working,… in the arduino ide serial monitor shows manual mode even though it is in automation mode. here is the code.
topr= analogRead(A2);
topl= analogRead(A3);
botl= analogRead(A4);
botr= analogRead(A5);
Vout=(analogRead(A1) * 5.0) / 1023;
analogVoltage = analogRead(voltageinputPIN); //reads analog voltage of incoming sensor
Serial.println(" Manual-mode");
if
(digitalRead(3)==HIGH){
Serial.println(" Automatic-mode");
servoh = servo_x.read();
servov = servo_z.read();
int avgtop = (topr + topl) / 2;
int avgbot = (botr + botl) / 2;
int avgright = (topr + botr) / 2;
int avgleft = (topl + botl) / 2;
int diffhori= avgtop - avgbot;
int diffverti= avgleft - avgright;
int offset =20;// set the correction offset value
/*tracking according to horizontal axis*/
if (abs(diffhori) <= threshold_value)
servo_x.write(servoh); //stop the servo up-down
}else {
if (diffhori > threshold_value)
{ Serial.println(" x - 2 ");
servo_x.write(servoh -2); //Clockwise rotation CW
if (servoh > servohLimitHigh)
servoh = servohLimitHigh;
delay(10);
}else {
servo_x.write(servoh +2); //CCW
if (servoh < servohLimitLow)
servoh = servohLimitLow;
delay(10);
/*tracking according to vertical axis*/
if (abs(diffverti) <= threshold_value)
servo_z.write(servov); //stop the servo left-right
}else{
if (diffverti > threshold_value)
servo_z.write(servov -2); //CW
if (servov > servovLimitHigh)
servov = servovLimitHigh;
delay(10);
}else{
servo_z.write(servov +2); //CCW
if (servov < servovLimitLow)
servov = servovLimitLow;
delay(10);
