Greetings Gents,
I faced a problem when I try to perform the below project. I developed the dashboard but I can not controller. It goes offline once I try to change the servo moter speed and there are no live parameters in the gauges.
PROJECT: IoT based solar tracker system / the embedded software
Aboubakr El Hammoumi/ aboubakr.elhammoumi@usmba.ac.ma
#include <CayenneMQTTEthernet.h> //CayenneMQTT library
#include <Servo.h> //Servo motor library
#include <DHT.h> //DHT library
#define DHTTYPE DHT22
#define DHTPIN 2
DHT dht(DHTPIN,DHTTYPE);
//MQTT credentials
char username[]="498d2d00-afe2-11ea-883c-638d8ce4c23d";
char password[]="ab4a8f92d94033c01f6e18ce1d8a84d8c304c9c4";
char clientID[]="17798a40-b968-11ea-93bf-d33a96695544";
Servo servo_x; //up-down servomotor
int servoh = 0;
int servohLimitHigh = 170;
int servohLimitLow = 10;
Servo servo_z; //left-right servomotor
int servov = 0;
int servovLimitHigh = 170;
int servovLimitLow = 10;
int topl,topr,botl,botr;
int threshold_value=10;
float Vout;
{ Serial.begin(9600);
servo_x.attach(5);
servo_z.attach(6);
dht.begin();
pinMode(3,OUTPUT);
digitalWrite(3,LOW);
{ topr= analogRead(A2);
topl= analogRead(A3);
botl= analogRead(A4);
botr= analogRead(A5);
Vout=(analogRead(A1) * 5.0) / 1023;
Serial.println(" Manual-mode");
if (digitalRead(3)==HIGH){
Serial.println(" Automatic-mode");
servoh = servo_x.read();
servov = servo_z.read();
int avgtop = (topr + topl) / 2;
int avgbot = (botr + botl) / 2;
int avgright = (topr + botr) / 2;
int avgleft = (topl + botl) / 2;
int diffhori= avgtop - avgbot;
int diffverti= avgleft - avgright;
/*tracking according to horizontal axis*/
if (abs(diffhori) <= threshold_value)
servo_x.write(servoh); //stop the servo up-down
}else {
if (diffhori > threshold_value)
{ Serial.println(" x - 2 ");
servo_x.write(servoh -2); //Clockwise rotation CW
if (servoh > servohLimitHigh)
servoh = servohLimitHigh;
delay(10);
}else {
servo_x.write(servoh +2); //CCW
if (servoh < servohLimitLow)
servoh = servohLimitLow;
delay(10);
/*tracking according to vertical axis*/
if (abs(diffverti) <= threshold_value)
servo_z.write(servov); //stop the servo left-right
}else{
if (diffverti > threshold_value)
servo_z.write(servov -2); //CW
if (servov > servovLimitHigh)
servov = servovLimitHigh;
delay(10);
}else{
servo_z.write(servov +2); //CCW
if (servov < servovLimitLow)
servov = servovLimitLow;
delay(10);
// Cayenne Functions
CAYENNE_IN(8){
int value = getValue.asInt();
CAYENNE_LOG("Channel %d, pin %d, value %d", 8, 3, value);
digitalWrite(3,value);
CAYENNE_IN(7){ //up-down servo motor
if (digitalRead(3)==HIGH){ //Automatic_mode
else{ //Manual_mode
servo_x.write(getValue.asDouble() * 180);
CAYENNE_IN(6){ //left-right servo motor
else{
servo_z.write(getValue.asDouble() * 180);
CAYENNE_OUT(0) { //Current
float current = Vout/10;
Cayenne.virtualWrite(0, current);
Serial.print("Current: ");
Serial.println(current);
CAYENNE_OUT(1) { //Voltage
float voltage = Vout * 2;
Cayenne.virtualWrite(1, voltage);
Serial.print("Voltage: ");
Serial.println(voltage);
CAYENNE_OUT(2){ //LDR Top-right
Cayenne.virtualWrite(2, topr);
CAYENNE_OUT(3){ //LDR Top-left
Cayenne.virtualWrite(3,topl);
CAYENNE_OUT(4){ //LDR Bot-left
Cayenne.virtualWrite(4,botl);
CAYENNE_OUT(5){ //LDR Bot-right
Cayenne.virtualWrite(5,botr);
CAYENNE_OUT(10) { //Power
float power = (Vout * 2 * Vout)/10 ;
Cayenne.virtualWrite(10, power);
Serial.print("Power: ");
Serial.println(power);
CAYENNE_OUT(11){ //Temperature
//int chk = dht.read(DHT11PIN);
Cayenne.virtualWrite(11, t, TYPE_TEMPERATURE, UNIT_CELSIUS);
Serial.print("temperature: ");
Serial.println(t);
CAYENNE_OUT(12){ //Huidity
float h = dht.readHumidity();
Cayenne.virtualWrite(12, h);
Serial.print(" humidity: ");
Serial.println(h);
