About This Project
How about you get a personal voice assistant like Jarvis from iron man movie, to control actuator or get the sensor data from the cayenne dashboard. this project does it and is quite simple.
First, get familiar with cayenne API Python code to access basic cayenne API
What’s Connected
Arduino, raspberry pi or any device connected to cayenne.
A device like raspberry pi with a mic and speaker to get receive the audio and playback. (i have used my laptop)
Dashboard Screenshots
Video
Code:
import os
import time
import speech_recognition as sr
import pyttsx3
import requests
import base64
import configparser
config = configparser.ConfigParser()
mqtt_username = ""
mqtt_password = ""
client_id = ""
client_secret = ""
username = ""
password = ""
device_id = ""
sensor_id_temp = ""
channel_light = 5
Wake = "hey jarvis"
def speak(text):
engine = pyttsx3.init()
engine.setProperty('voice', 'com.apple.speech.synthesis.voice.daniel')
engine.say(text)
engine.runAndWait()
def get_audio():
r = sr.Recognizer()
with sr.Microphone() as source:
audio = r.listen(source)
said = ""
try:
said = r.recognize_google(audio)
print(said)
except Exception as e:
print("Exception: " + str(e))
return said.lower()
def get_mqtt_token(mqtt_username, mqtt_password):
string = mqtt_username + ':' + mqtt_password
print(string)
data = base64.b64encode(string.encode())
mqtt_token = data.decode("utf-8")
#config['DEFAULT']['mqtt_token'] = mqtt_token
# with open('credentials.ini', 'w') as configfile:
# config.write(configfile)
return (mqtt_token)
def get_access_token(client_id, client_secret, username, password):
response = requests.post('https://accounts.mydevices.com/auth/realms/cayenne/protocol/openid-connect/token',
data={'grant_type': 'password',
'client_id': client_id,
'client_secret': client_secret,
'username': username,
'password': password},
headers={'content-type': 'application/x-www-form-urlencoded'})
payload = response.json()
access_token = payload['access_token']
print('Access_Token = ' + access_token)
#config['DEFAULT']['access_token'] = access_token
return (access_token)
def get_latest_history(access_token, device_id, sensor_id):
bearer = 'Bearer ' + access_token
URL = 'https://platform.mydevices.com/v1.1/telemetry/' + \
device_id+'/sensors/'+sensor_id+'/summaries?type=latest'
response = requests.get(URL,
headers={'authorization': bearer},)
data = payload[0]['v']
print('Data history = %d' % data)
return data
def publish_actuator_data(access_token, device_id, channel, value):
# URL = 'https://api.mydevices.com/things/'+device_id+'/data'
#URL = 'https://platform.mydevices.com/v1.1/telemetry/' +device_id+'/cmd'
URL = 'https://platform.mydevices.com/v1.1/things/'+device_id+'/cmd'
basic = 'Bearer ' + access_token
headers = {'authorization': basic,
'content-type': 'application/json'}
data = {'value': value,
'channel': channel
response = requests.post(URL, json=data, headers=headers)
print(response)
#speak("welcome to cayenne smart home")
access_token = get_access_token(client_id, client_secret, username, password)
mqtt_token = get_mqtt_token(mqtt_username, mqtt_password)
print(access_token)
speak("hello")
while True:
print("listing")
text = get_audio()
if text.count(Wake) > 0:
print("what")
speak("Hi shramik. what do you want me to do")
text = get_audio()
if "what is the temperature in the living room" in text:
data = get_latest_history(access_token, device_id, sensor_id_temp)
#data = "the current temperature " + data
data = 'the living room temperature is %d celsious' % data
print(data)
speak(data)
elif "turn on the living room light" in text:
publish_actuator_data(access_token, device_id, channel_light, 1)
speak("the living room light is turned on")
elif "turn off the living room light" in text:
publish_actuator_data(access_token, device_id, channel_light, 0)
speak("the living room is light turned off")
