Dear All,
I have connected a WiMod LoRa module to Actility and trying to connect it to Cayenne dashboard through LPP.
When I run the script I get the following error :
CayenneLPP::~CayenneLPP(void) {
C:\Users\Spiros\Documents\Arduino\libraries\CayenneLPP-master\src\CayenneLPP.cpp:15:1: note: code may be misoptimized unless -fno-strict-aliasing is used
collect2.exe: error: ld returned 1 exit status
Any ideas please? The code is attached in a text file
Has anyone come acroos this error please?
Please find the code below:
#include <CayenneLPP.h>
#include <WiMODLoRaWAN.h>
#if defined(ARDUINO_ARCH_AVR)
#include <avr/pgmspace.h>
#endif
// Set your AppEUI and AppKey
const char *appEui = "";
const char *appKey = ")";
#define loraSerial Serial1
#define debugSerial Serial
// Replace REPLACE_ME with TTN_FP_EU868 or TTN_FP_US915
//#define freqPlan REPLACE_ME
//TheThingsNetwork ttn(loraSerial, debugSerial, freqPlan);
//CayenneLPP lpp(51);
// platform defines
* Note: This sketch is for Arduino devices with two separate serial interfaces
* (e.g. DUE). One interface is connected to a PC and one is used for WiMOD.
* For single serial interface boards (e.g. UNO) it is recommended to disbale
* the PC / Debug messages
#define WIMOD_IF Serial3 // for WiMODino use: SerialWiMOD
#define PC_IF Serial // for WiMODino use: SerialUSB
// constant values
* OTAA Parameters
// application key (64bit)
const unsigned char APPEUI[] = { };
// application key (128bit)
const unsigned char APPKEY[] = { };
int txdata = 30;
// user defined types
typedef enum TModemState
ModemState_Disconnected = 0,
ModemState_ConnectRequestSent,
ModemState_Connected,
ModemState_FailedToConnect,
} TModemState;
typedef struct TRuntimeInfo
TModemState ModemState;
} TRuntimeInfo;
// section RAM
* Create in instance of the interface to the WiMOD-LR-Base firmware
WiMODLoRaWAN wimod(WIMOD_IF); // use the Arduino Serial3 as serial interface
TRuntimeInfo RIB = { };
static uint32_t loopCnt = 0;
static TWiMODLORAWAN_TX_Data txData;
// section code
* Function for printing out some debug infos via serial interface
void debugMsg(String msg)
PC_IF.print(msg); // use default Arduino serial interface
void debugMsg(int a)
PC_IF.print(a, DEC);
void debugMsgChar(char c)
PC_IF.print(c);
void debugMsgHex(int a)
if (a < 0x10) {
PC_IF.print(F("0"));
PC_IF.print(a, HEX);
* join tx indication callback
void onJoinTx(TWiMODLR_HCIMessage& rxMsg) {
TWiMODLORAWAN_TxIndData txData = {};
wimod.convert(rxMsg, &txData);
debugMsg(F("joining attempt: "));
if (txData.FieldAvailability == LORAWAN_OPT_TX_IND_INFOS_INCL_PKT_CNT) {
debugMsg((int) txData.NumTxPackets);
debugMsg(F("\n"));
* joined network indication
void onJoinedNwk(TWiMODLR_HCIMessage& rxMsg) {
TWiMODLORAWAN_RX_JoinedNwkData joinedData;
debugMsg(F("Join-Indication received.\n"));
if (wimod.convert(rxMsg, &joinedData)) {
if ((LORAWAN_JOIN_NWK_IND_FORMAT_STATUS_JOIN_OK == joinedData.StatusFormat)
|| (LORAWAN_JOIN_NWK_IND_FORMAT_STATUS_JOIN_OK_CH_INFO == joinedData.StatusFormat)){
//Ok device is now joined to nwk (server)
RIB.ModemState = ModemState_Connected;
debugMsg(F("Device has joined a network.\n"));
debugMsg(F("New Device address is: "));
debugMsg((int) joinedData.DeviceAddress);
debugMsg(F("\n"));
} else {
// error joining procedure did not succeed
RIB.ModemState = ModemState_FailedToConnect;
debugMsg(F("Failed to join a network.\n"));
* rx data callback
void onRxData(TWiMODLR_HCIMessage& rxMsg) {
TWiMODLORAWAN_RX_Data radioRxMsg;
int i;
debugMsg("Rx-Data Indication received.\n");
// convert/copy the raw message to RX radio buffer
if (wimod.convert(rxMsg, &radioRxMsg)) {
if (radioRxMsg.StatusFormat & LORAWAN_FORMAT_ACK_RECEIVED) {
// yes, this is an ack
debugMsg(F("Ack-Packet received."));
// print out the received message as hex string
if (radioRxMsg.Length > 0) {
// print out the length
debugMsg(F("Rx-Message: ["));
debugMsg(radioRxMsg.Length);
debugMsg(F("]: "));
// print out the payload
for (i = 0; i < radioRxMsg.Length; i++) {
debugMsgHex(radioRxMsg.Payload[i]);
debugMsg(F(" "));
debugMsg(F("\n"));
} else {
// no payload included
// debugMsg(F("Rx-Message with no Payload received; Status: "));
// debugMsg((int) radioRxMsg.StatusFormat);
debugMsg(F("\n"));
* print out a welcome message
void printStartMsg()
debugMsg(F("==================================================\n"));
debugMsg(F("This is FileName: "));
debugMsg(F(__FILE__));
debugMsg(F("\r\n"));
debugMsg(F("Starting...\n"));
debugMsg(F("This simple demo will try to "));
debugMsg(F("do the OTAA procedure and "));
debugMsg(F("send a demo message each 30 sec.\n"));
* Arduino setup function
loraSerial.begin(57600);
debugSerial.begin(9600);
DynamicJsonDocument jsonBuffer(4096);
CayenneLPP lpp(160);
JsonArray root = jsonBuffer.to<JsonArray>();
Serial.begin(115200);
Serial.println();
// wait for the PC interface to be ready (max 10 sec); usefull for USB
while (!PC_IF && millis() < 10000 ){}
// init / setup the serial interface connected to WiMOD
WIMOD_IF.begin(WIMOD_LORAWAN_SERIAL_BAUDRATE);
// init the communication stack
wimod.begin();
// debug interface
PC_IF.begin(115200);
printStartMsg();
// do a software reset of the WiMOD
delay(100);
wimod.Reset();
delay(100);
// deactivate device in order to get a clean start for this demo
wimod.DeactivateDevice();
// do a simple ping to check the local serial connection
debugMsg(F("Ping WiMOD: "));
if (wimod.Ping() != true) {
debugMsg(F("FAILED\n"));
} else {
debugMsg(F("OK\n"));
// try to register the device at network server via OTAA procedure
debugMsg(F("Starting join OTAA procedure...\n"));
TWiMODLORAWAN_JoinParams joinParams;
//setup OTAA parameters
memcpy(joinParams.AppEUI, APPEUI, 8);
memcpy(joinParams.AppKey, APPKEY, 16);
// transfer parameters to WiMOD
wimod.SetJoinParameter(joinParams);
// Register callbacks for join related events
wimod.RegisterJoinedNwkIndicationClient(onJoinedNwk);
wimod.RegisterJoinTxIndicationClient(onJoinTx);
// send join request
if (wimod.JoinNetwork()) {
RIB.ModemState = ModemState_ConnectRequestSent;
debugMsg(F("...waiting for nwk response...\n"));
} else {
debugMsg("Error sending join request: ");
debugMsg((int) wimod.GetLastResponseStatus());
debugMsg(F("\n"));
// Wait a maximum of 10s for Serial Monitor
while (!debugSerial && millis() < 10000)
debugSerial.println("-- STATUS");
lpp.reset();
lpp.addUnixTime(1, 135005160);
lpp.addTemperature(1, 22.5);
//lpp.addBarometricPressure(2, 1073.21);
//lpp.addGPS(3, 52.37365, 4.88650, 2);
* Arduino loop function
// check of OTAA procedure has finished
if (RIB.ModemState == ModemState_Connected) {
// send out a hello world every 30 sec ( =6* 50*100 ms)
// (due to duty cycle restrictions 30 sec is recommended
if ((loopCnt > 1) && (loopCnt % (6*50)) == 0) {
// send out a simple HelloWorld messsage
debugMsg(F("Sending HelloWorld message...\n"));
// prepare TX data structure
txData.Port = 0x01;
txData.Length = strlen_P(PSTR("Hello World!"));
strcpy_P((char*) txData.Payload, PSTR("Hello World!"));
// try to send a message
if (false == wimod.SendUData(&txData)) {
// an error occurred
// check if we have got a duty cycle problem
if (LORAWAN_STATUS_CHANNEL_BLOCKED == wimod.GetLastResponseStatus()) {
// yes; it is a duty cycle violation
// -> try again later
debugMsg(F("TX failed: Blocked due to DutyCycle...\n"));
// check for any pending data of the WiMOD
wimod.Process();
delay(100);
loopCnt++;
debugSerial.println("-- LOOP");
// Send it off
// ttn.sendBytes(lpp.getBuffer(), lpp.getSize());
delay(10000);
