Não consigo conectar- fica o tempo todo esperando conectar
#include <Ethernet.h>
#include <dht.h>
char username [] = "ce" ;
char password [] = "aaa94d" ;
char clientID [] = "6caf" ;
#define SENSOR_PIN 0
#define VIRTUAL_CHANNEL 1
int outPin = 13;
#define dht_dpin A1 //Pino DATA do Sensor ligado na porta Analogica A1
dht DHT; //Inicializa o sensor
  pinMode (outPin,OUTPUT );
  delay(1000);//Aguarda 1 seg antes de acessar as informações do sensor
	DHT.read11(dht_dpin); //Lê as informações do sensor
  Serial.print("Umidade = ");
  Serial.print(DHT.humidity);
  Serial.print(" %  ");
  Serial.print("Temperatura = ");
  Serial.print(DHT.temperature);
  Serial.println(" Celsius  ");
   if (DHT.temperature>30)
    digitalWrite(outPin, HIGH);
   else
    digitalWrite(outPin, LOW);
CAYENNE_OUT(VIRTUAL_CHANNEL)
	Cayenne.virtualWrite(VIRTUAL_CHANNEL, analogRead(SENSOR_PIN));
add #define CAYENNE_DEBUG in your code and check the issue in your serial monitor.
